- Thank you received: 907
Beginner Plasmac Questions
- snowgoer540
Clive S wrote:
Also, the manual for my machine specifies Edge Start rather than piercing after a certain thickness. To accomplish this I assume I'm going to have to Disable ArcOk, right?
If it is only at the edge, a work around is to put a bit of dummy metal at the edge and start the cut there.
I suppose you could also re-enable it during a cut. For example, say you were cutting a 12" line in X:
I've not tested that exact scenario personally, but I would think because you are cutting at a set height, and thick material isnt as bendy usually as sheetmetal, if you checked auto volts it would just start controlling the THC as usual, and control based on the height you had set at the beginning of the cut.
- phillc54
- Thank you received: 2100
That should work fine. Probably better to use M63 instead of M65 as there is motion after so you can be sure when the re-enable will happen.snowgoer540 wrote:
Code:M62 P1 (turn arc ok off) M3 command G1 X0.125 (or whatever distance you're sure you're into material) M65 P1 (turn arc ok back on) G1 X12 M5
- snowgoer540
:blush: I still get the two confused. You’re right, M63 would be better!
Also glad we found another use for ignoring the arc-ok!
- AgentWD40
- Thank you received: 96
- Thank you received: 4153
If this setting was enabled, you could generate code on the start of the job to turn off the arcOK and reenable it at the end of the job. If you wanted to use ArcOK again, you would need to create a seperate sheetcam layer and a define a new tool that did not "Use Edge Start".
This does not need any changes to Plasmac, just a tweak to the Sheetcam Post processor.
