Beginner Plasmac Questions
24 Aug 2020 09:28 #179245 by snowgoer540
Replied by snowgoer540 on topic Beginner Plasmac Questions
How do I get these parts to start at where I jog the torch to?
When you move the torch to where you want in X and Y, hit Touch off, and change it to 0 for each axis. I'm not sure if you're using Axis or Gmoccapy. But that's the process for Axis. Should be similar for Gmoccapy.
The following user(s) said Thank You: AgentWD40
  • Moderator
  • Moderator
24 Aug 2020 12:51 #179264 by tommylight
Replied by tommylight on topic Beginner Plasmac Questions
Nice, making some coins ! :)
24 Aug 2020 14:47 #179268 by rodw
Replied by rodw on topic Beginner Plasmac Questions
You should be able to program one of the gmoccapy macro buttons touch off x & y with one mouse press. I have a macro that moves to a laser pointer cross hair and touches off. Saves a lot of time...
25 Aug 2020 15:08 - 25 Aug 2020 15:10 #179444 by hermann1976
Replied by hermann1976 on topic Beginner Plasmac Questions
tommylight wrote: Try the buster version from here, it should work:
pkgs.org/download/dxf2gcode
Thanks Tom, it install and opens but it crashes on every dxf file I tried. I went back as far as release 12 DXF but still no go. I do remember using it years ago.
look at here:
forum.linuxcnc.org/post-processors/39856...to-install-dxf2gcode
let me know if it works!
Last edit: 25 Aug 2020 15:10 by hermann1976.
  • AgentWD40
  • AgentWD40's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Aug 2020 18:19 #179462 by AgentWD40
Replied by AgentWD40 on topic Beginner Plasmac Questions
Is there a way to tell sheetcam to reduce speed for holes or does plasmac automatically do that?
Or do I have to put small holes on a different layer in plasmac and set up a custom tool?
25 Aug 2020 18:23 #179463 by phillc54
Replied by phillc54 on topic Beginner Plasmac Questions
You can do it in Sheetcam or PlasmaC can do it via the filter program:
linuxcnc.org/docs/2.8/html/plasma/plasma...de.html#hole-cutting
  • AgentWD40
  • Platinum Member
  • Platinum Member
25 Aug 2020 18:40 #179467 by AgentWD40
Oh great! Do lead-ins or lead-outs from sheetcam, or cam, interfere with plasmac autodetecting holes.
25 Aug 2020 18:48 #179468 by phillc54
They shouldn't.
25 Aug 2020 19:41 #179474 by rodw
Shouldn't do.
  • AgentWD40
  • Platinum Member
  • Platinum Member
27 Aug 2020 01:23 - 27 Aug 2020 01:24 #179658 by AgentWD40
Does the " Manual Single Cut " use THC?
Also, the manual for my machine specifies Edge Start rather than piercing after a certain thickness. To accomplish this I assume I'm going to have to Disable ArcOk, right?
M63 P1 or M65 P1 (disable Ignore Arc OK)
Finally, if I disable ArcOk per above, will it ever automatically be reenabled? Like when I load a new gcode, reset the machine, or maybe after each cut?
Last edit: 27 Aug 2020 01:24 by AgentWD40.
