How best to use this height sensor
- mariusl
26 Aug 2020 07:18 #179531
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic How best to use this height sensor
Awesome Phill thanks a lot. I will machine the bracket today and fit tomorrow. I will report back
Regards
Marius
www.bluearccnc.com
- Clive S
- Thank you received: 486
26 Aug 2020 07:34 #179532
by Clive S
Its a nice idea but looking at the vid. it seems to sense the highest point ie. I notice where the metal warps up to the left of the torch that is where is sensed to and not where the actual torch was it does the same at other locations.
Just my 2 c worth
Replied by Clive S on topic How best to use this height sensor
Just my 2 c worth
- snowgoer540
- Thank you received: 907
26 Aug 2020 07:56 #179534
by snowgoer540
I actually thought the same...
Replied by snowgoer540 on topic How best to use this height sensor
Just my 2 c worth
- Thank you received: 7506
26 Aug 2020 08:04 #179537
I did try that way some 8 years back, it did not work, it gets to the edge of the material or over a part that has already fallen off and it goes .......
That is just an expensive and annoying way to save 70$ for a Mesa THCAD.
Replied by tommylight on topic How best to use this height sensor
+1
Just my 2 c worth
- mariusl
26 Aug 2020 08:33 #179541
by mariusl
Regards
Marius
www.bluearccnc.com
Point taken. The sensors are only 30mm from the center point of the torch so not a lot of space for serious warping.
Regards
Marius
www.bluearccnc.com
- snowgoer540
26 Aug 2020 09:22 #179547
by snowgoer540
But as Tommy says, tip ups and all that nonsense are going to be attracted to those height sensors like moths to flames.
- mariusl
26 Aug 2020 14:08 #179566
by mariusl
Not if you live in my country. To get is here with courier and import duties it will be $140 and at 17.5 to the dollar, it looks really shitty on my end. So not exactly true
Regards
Marius
www.bluearccnc.com
Regards
Marius
www.bluearccnc.com
- Thank you received: 4155
26 Aug 2020 14:18 #179568
Well, you could just use a couple of relays like this proven method for ohmic sensing.
linuxcnc.org/docs/2.8/html/plasma/plasma...r.html#ohmic-sensing
Replied by rodw on topic How best to use this height sensor
26 Aug 2020 15:28 #179576
Damn, i thought i am the only one here having to jump through a lot of hoops to get Mesa stuff! Last 4 of THCAD i got came to about 115$ a piece.
Time to create page: 0.731 seconds
