Plasmac migration problems
- Mud
- Thank you received: 25
30 Aug 2020 06:31 #180055
by Mud
Plasmac migration problems was created by Mud
I've spent a little bit of time trying to fix this, but I've lost my bearings a bit (sheer number of files in a plasmac install!). I've run the config wizard, but on trying to open axis (via terminal command, as per guide) I get the error "incorrect [TRAJ]LINEAR_UNITS in ini file", which I don't understand. It says LINEAR_UNITS = metric in mud_plasmac.ini, which appears valid.
My initial config was made using the 7i96 wizard with a few tweaks, and it seemed like the contents of io.hal didn't make their way into the plasmac config. Correctly or not, I've put the contents from io.hal into mud_plasmac_conenections, and I can home and jog the machine.
- phillc54
- Thank you received: 2100
30 Aug 2020 06:35 #180057
by phillc54
Replied by phillc54 on topic Plasmac migration problems
Try mm instead of metric.
The following user(s) said Thank You: Mud
- Mud
30 Aug 2020 06:49 #180058
by Mud
Replied by Mud on topic Plasmac migration problems
- Mud
30 Aug 2020 07:41 #180063
by Mud
I can't get it to do the test probe, the button just immediately lights and starts counting down - any ideas? I'm assuming it's something daft...the float switch seems fine, so I'm assuming it's config.
- Thank you received: 7509
30 Aug 2020 18:01 #180116
Replied by tommylight on topic Plasmac migration problems
Set pierce height to 3mm and cut height to 1.5mm.
- phillc54
30 Aug 2020 20:57 #180127
by phillc54
Your Setup Speed is wayyyy too low.
- Mud
31 Aug 2020 04:55 #180140
by Mud
We're close...it probes - is it meant to be Setup Speed that controls the speed of the final movement up (to the height where it waits for a pierce command)? It doesn't seem to be, but I can't find something else to alter (it's too slow, and on an unfortunate motor resonance).
- phillc54
31 Aug 2020 04:58 #180141
by phillc54
Setup speed is all Z axis motion except for:
Probing, but probing maximum speed is setup speed.
THC, which can use Z MAX_VELOCITY if needed.
- Mud
31 Aug 2020 05:16 #180142
by Mud
Looks like it's the slow (second) probe speed I can't find - apologies if blind, but where can I find it?
- phillc54
31 Aug 2020 05:38 #180144
by phillc54
The final probe up speed is always slow to maintain accuracy.
You must have a large hysteresis on your probe switch.
You could try reducing probe speed to reduce the overrun.
You could also try reducing the debounce in the <machine-name>_connections.hal file.
Time to create page: 0.298 seconds
