Probe Test And Setting Float Travel
- Thank you received: 4151
01 Jan 2022 20:25 #230478
Replied by rodw on topic Probe Test And Setting Float Travel
As little as possible. I added a grub screw in my z axis to take up as much pre-travel as I could.
It does not really matter but if you have a lot of travel, you waste a lot of time.
The following user(s) said Thank You: AgentWD40
- AgentWD40
- Thank you received: 96
01 Jan 2022 21:24 #230486
by AgentWD40
Replied by AgentWD40 on topic Probe Test And Setting Float Travel
Okay, thank you.
Not knowing what I don't know I wasn't sure if longer (more gradual) might have any benefit in regard to repeatability for a cheap mechanical limit switch.
Time to create page: 0.251 seconds
