Choosing a compressor for plasma cutting
- Thank you received: 1482
11 Sep 2020 16:33 #181770
Replied by Todd Zuercher on topic Choosing a compressor for plasma cutting
The ones with built in variable speed drives are very nice, They just hum along matching speed to demand maintaining a constant pressure, and using a lot less energy. We recently upgraded our shop supply from a few of Atlas Copco GS18 compressors (two vfds and one single speed) to two GA45, 60hp units (one VFD, one single speed). Yes, we use a lot of air, with 3 automated paint lines, numerous sanding booths, and a bunch of air tools and other stuff. I can't imagine doing all that with piston compressors, ick.
- fernandosf
- Thank you received: 17
07 Sep 2021 19:01 #219870
by fernandosf
Replied by fernandosf on topic Choosing a compressor for plasma cutting
I don't know how things are in your countries, but compressors of a single stage have a loss of about 50% from the theoretic air flow per minute. If the compressor is capable of 10 cfm theoretically, you can expect 5 cfm real.
compressors with 2 stages (where the second cylinder takes the output from the first cylinder) have a loss of 30%
screw compressors have near no loss.
- billykid
- Thank you received: 83
07 Sep 2021 19:56 #219877
by billykid
Replied by billykid on topic Choosing a compressor for plasma cutting
screw compressors are better in almost all respects, the air demand must be calculated well, better if they run continuously at the right temperature, otherwise many stops and starts tend to accumulate water in the oil.
Time to create page: 0.196 seconds
