setp plasmac.probe-final-speed / changing probe up speed in connections.hal
6 years 1 month ago #183577 by benbenben
Hello everyone,
according to linuxcnc.org/docs/2.8/html/plasma/plasmac-user-guide.html
It is possible to increase this speed by up to a factor of 10 by adding the following line to your <machine_name>_connections.hal file:
setp plasmac.probe-final-speed n
gives this error
twopass:found ./plasma_connections.hal
twopass: Error in file ./plasma_connections.hal:
setting parameter 'plasmac.probe-final-speed' to '5'
parameter or pin 'plasmac.probe-final-speed' not found
any suggestions?
machine is working and cutting with no errors
Best Ben
6 years 1 month ago - 6 years 1 month ago #183579 by snowgoer540
[strike]Believe it should be:[/strike]
Warning: Spoiler!
[strike]I am working on proof reading/updating the user guide. I will make sure to note the change. Thanks for pointing it out![/strike]
EDIT: Actually plasmac.probe-final-speed should be correct... What version of PlasmaC are you on? This was a feature that was recently added, and if you are before v0.170, that is the problem.
Last edit: 6 years 1 month ago by snowgoer540.
6 years 1 month ago #183615 by benbenben
ahh...ok, my version acc.to .ini 0.144. little scared to upgrade and maybe have to start from scratch
6 years 1 month ago #183619 by tommylight
How did you install LinuxCNC?
If it is a buildbot install, in aterminal:
sudo apt-get update
sudo apt-get dist-upgrade
6 years 1 month ago #183623 by benbenben
6 years 1 month ago #183640 by phillc54
benbenben wrote: ahh...ok, my version acc.to .ini 0.144. little scared to upgrade and maybe have to start from scratch
That is only the last major update, if you look at the bottom of the config panel next to the buttons it should show the version.
