setp plasmac.probe-final-speed / changing probe up speed in connections.hal
24 Sep 2020 12:27 #183577 by benbenben
Hello everyone,
according to linuxcnc.org/docs/2.8/html/plasma/plasmac-user-guide.html
It is possible to increase this speed by up to a factor of 10 by adding the following line to your <machine_name>_connections.hal file:
setp plasmac.probe-final-speed n
gives this error
twopass:found ./plasma_connections.hal
twopass: Error in file ./plasma_connections.hal:
setting parameter 'plasmac.probe-final-speed' to '5'
parameter or pin 'plasmac.probe-final-speed' not found
any suggestions?
machine is working and cutting with no errors
Best Ben
24 Sep 2020 12:35 - 24 Sep 2020 13:00 #183579 by snowgoer540
Believe it should be:
Warning: Spoiler!
I am working on proof reading/updating the user guide. I will make sure to note the change. Thanks for pointing it out!
EDIT: Actually plasmac.probe-final-speed should be correct... What version of PlasmaC are you on? This was a feature that was recently added, and if you are before v0.170, that is the problem.
Last edit: 24 Sep 2020 13:00 by snowgoer540.
24 Sep 2020 18:35 #183615 by benbenben
ahh...ok, my version acc.to .ini 0.144. little scared to upgrade and maybe have to start from scratch
  • Moderator
  • Moderator
24 Sep 2020 20:33 #183619 by tommylight
How did you install LinuxCNC?
If it is a buildbot install, in aterminal:
sudo apt-get update
sudo apt-get dist-upgrade
24 Sep 2020 20:59 #183623 by benbenben
thanks tommy ill try that out
24 Sep 2020 22:53 #183640 by phillc54
That is only the last major update, if you look at the bottom of the config panel next to the buttons it should show the version.
25 Sep 2020 10:59 #183703 by benbenben
After update (with no hassle) works like charm, Thanks for the help :)
i have the probe up speed at 10, is there a way to bump that up even further and can someone guide me in the right direction e,g. docs, was thinking on percentage of probe down speed or, probably easier to implement keeping the factor but making it faster
Best
25 Sep 2020 11:05 - 25 Sep 2020 11:07 #183704 by phillc54
Line 787 here:
github.com/LinuxCNC/linuxcnc/blob/master...ponents/plasmac.comp
I was reluctant to take it much higher in case it affects the probed height too much.
Last edit: 25 Sep 2020 11:07 by phillc54.
The following user(s) said Thank You: Mud
25 Sep 2020 11:22 - 25 Sep 2020 11:23 #183705 by Mud
I found 5 ok - would be interested to see what it looks like on your rig if possible :)
Thanks again for implementing the feature Phill.
Last edit: 25 Sep 2020 11:23 by Mud.
  • Moderator
  • Moderator
25 Sep 2020 11:26 #183706 by tommylight
+1
I was in agony because of this, having an immensely fast machine waiting for so long.... :)
Time to create page: 0.172 seconds
