setp plasmac.probe-final-speed / changing probe up speed in connections.hal
6 years 1 month ago #183709 by phillc54
Clive S wrote:
phillc54 wrote:
tommylight wrote:
Mud wrote: Thanks again for implementing the feature Phill.
+1
I was in agony because of this, having an immensely fast machine waiting for so long.... :)
Yes, I was a bit slow on the uptake with this. :dry:
You need to pull your socks up Phill B) :ohmy:
Haha, I would if they weren't full of holes. :silly:
6 years 1 month ago #183731 by benbenben
phillc54 wrote: Line 787 here:
github.com/LinuxCNC/linuxcnc/blob/master...ponents/plasmac.comp
I was reluctant to take it much higher in case it affects the probed height too much.
great phil, i thought i have to spend days figuring that out programming and debugging now i just can just focus on recompiling or whatever is necessary to get it in my config:pinch:
@Mud
setp plasmac.probe-final-speed 10
The following user(s) said Thank You: tommylight, Mud
6 years 1 month ago - 6 years 1 month ago #183747 by Mud
Thanks - I can see you have a lot of overshoot, so that demonstrates why you want the high speed :)
edit: your lower bearing housing looks loose btw.
Last edit: 6 years 1 month ago by Mud.
6 years 1 month ago #183764 by phillc54
@benbenben
Wow, you have a LOT of hysteresis in that setup.
6 years 1 month ago #183815 by tommylight
phillc54 wrote: @benbenben
It looks like a 12mm sensor, so he would end up having 13 to 14mm of hysteresis , depending on the sensor sensitivity.
6 years 1 month ago #183817 by phillc54
That is something I had not considered, my float switch is a mechanical microswitch with very little hysteresis. Maybe I should increase the limit of 10 and folk can setup whatever suits them, although I must admit that I thought X10 would be plenty.
Time to create page: 0.207 seconds
