Inkscape PlasmaC g-code generation
- Thank you received: 7488
13 Oct 2020 22:13 #186035
And i did try to add PlasmaC feed rate but it would not accept non numerical values, so i had to move on after some 20 wasted minutes to other stuff and never got a chance to get back to it.
Thank you for the solution, will try to do a how to edit gcodetools.py if at all possible.
Replied by tommylight on topic Inkscape PlasmaC g-code generation
I modify the gcodetools.py file, always.I'm curious how @tommylight handles this.
fwiw I've poked around the gcode extension's python code and figured out how to make it output #<_hal[plasmac.cut-feed-rate]>. Untested and I don't recommend it but hey, maybe it'll be fine.
Around line #3337 change:
f = " F{:f}".format(tool)
to
f = " F{}".format(tool)
Line 5158 change:
"feed": 400.,
to
"feed": "#<_hal[plasmac.cut-feed-rate]>",
(you can change the rest of your defaults here too)
Line 5347 just comment it out:
self.tool["feed"] = float(self.tool["feed"])
to
#self.tool["feed"] = float(self.tool["feed"])
Line 3091 change:
"feed": 400.0,
to
"feed": "400.0",
I think that's all the changes I made... again, I don't recommend it
The following user(s) said Thank You: AgentWD40
- AgentWD40
- Thank you received: 96
14 Oct 2020 01:40 #186052
by AgentWD40
Replied by AgentWD40 on topic Inkscape PlasmaC g-code generation
It might not be too bad to set up the plugin to read a material.cfg file and give the user a drop down to select a material.
The following user(s) said Thank You: Doug @ Design8Studio.com
Time to create page: 0.087 seconds
