LinuxCNC Does not recognize THC
  • MakingStuff
  • MakingStuff's Avatar Topic Author
  • Premium Member
  • Premium Member
22 Oct 2020 17:59 - 22 Oct 2020 17:59 #186916 by MakingStuff
LinuxCNC Does not recognize THC was created by MakingStuff
I noticed today that LinuxCNC has stopped recognizing my THC. The up and down LEDs on the GUI do not light up and the torch height does not change. The THC is sending the signals on the correct pins because I can see the LEDs on my Mesa 7i96 board light up when the THC activates the up or down pin.
I updated to the most recent version with buildbot and also ran the Plasmac upgrade utility and that did not work. I also looked at the configuration with the utility and it show the correct gpio pins for up and down.
Everything else works fine, just the THC is not being recognized. Not sure what to do next. Any help would be appreciated.
Bob
Last edit: 22 Oct 2020 17:59 by MakingStuff.
22 Oct 2020 18:42 #186920 by snowgoer540
Replied by snowgoer540 on topic LinuxCNC Does not recognize THC
In the config tab there should be a version number, let us know what it is. Also, there’s a backup button if your setup really is up to date, please post the resulting file here, it may help us diagnose!
  • MakingStuff
  • Premium Member
  • Premium Member
22 Oct 2020 21:43 #186932 by MakingStuff
Replied by MakingStuff on topic LinuxCNC Does not recognize THC
Backup file is attached. The version is 0.180.
I forgot to mention in my first post that this has been working for around a year and has just recently stopped. The Arc OK and Float Switch work fine. It's just the THC pins that have stopped responding.
Bob
22 Oct 2020 22:52 - 22 Oct 2020 22:52 #186938 by phillc54
Replied by phillc54 on topic LinuxCNC Does not recognize THC
Do the THC Enable and THC Active LEDs light up?
If they do and the UP/Down LEDs don't light up can you check the HAL pins plasmac.move-up and plasmac.move-down. They should turn on when they get the corresponding up/down signal from your THC controller.
Last edit: 22 Oct 2020 22:52 by phillc54.
  • MakingStuff
  • Premium Member
  • Premium Member
22 Oct 2020 23:47 #186944 by MakingStuff
The THC enabled does light up when the radio button is set to Auto or Enabled. It goes out when the radio button is set to disabled. The THC Active does not light up.
Where do I find the plasmac.move-up and plasmac.move-down HAL pins?
  • MakingStuff
  • Premium Member
  • Premium Member
22 Oct 2020 23:51 #186945 by MakingStuff
I found the move-up / move-down pins and they appear to be set correct because they are connected to gpio pins 1 & 2. Those pins corresponding leds light up on the Mesa board when the THC set the pin high. The arc ok and float switch work as they should.
net plasmac:arc-ok-in hm2_7i96.0.gpio.000.in => plasmac.arc-ok-in
net plasmac:float-switch hm2_7i96.0.gpio.003.in => debounce.0.0.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => debounce.0.1.in
# net plasmac:ohmic-probe {YOUR OHMIC PROBE PIN} => debounce.0.2.in
# net plasmac:ohmic-enable plasmac.ohmic-enable => {YOUR OHMIC ENABLE PIN}
net plasmac:torch-on => hm2_7i96.0.ssr.00.out-00
net plasmac:move-up hm2_7i96.0.gpio.001.in => plasmac.move-up
net plasmac:move-down hm2_7i96.0.gpio.002.in => plasmac.move-down
22 Oct 2020 23:52 #186946 by phillc54
From the Axis menu: Machine >> Show Hal Configuration >> Pins >> plasmac, select the Watch panel on the right then select the two pins from the tree.
Then you can observe them as the THC controller changes.
  • MakingStuff
  • Premium Member
  • Premium Member
23 Oct 2020 00:10 #186948 by MakingStuff
When I watch the move-up and move-down pins in hal config they light up when the THC sets the pins high. The LEDs in the GUI and in hal config do not light up. THC active does not light up either.
23 Oct 2020 00:28 #186950 by phillc54
Not sure there...
Is THC Enabled LED lit?
Is VAD Lock LED lit?
Your config does work fine here in a simulator.
  • MakingStuff
  • Premium Member
  • Premium Member
23 Oct 2020 00:45 - 23 Oct 2020 02:45 #186952 by MakingStuff
THC Enabled is lit.
THC Active is not lit.
VAD is not lit. If I check the VAD check box, it still does not light up.
Last edit: 23 Oct 2020 02:45 by MakingStuff.
Time to create page: 0.527 seconds
