LinuxCNC Does not recognize THC
23 Oct 2020 00:50 #186953 by phillc54
Replied by phillc54 on topic LinuxCNC Does not recognize THC
Is this with all G-Code files?
Could you post an example.
23 Oct 2020 01:03 #186957 by phillc54
Is the Arc OK LED being lit?
23 Oct 2020 08:01 #186979 by tommylight
Replied by tommylight on topic LinuxCNC Does not recognize THC
Check the delay in the config tab, it must be set to some high value.
  • MakingStuff
  • MakingStuff's Avatar Topic Author
  • Premium Member
  • Premium Member
23 Oct 2020 12:52 #187000 by MakingStuff
Replied by MakingStuff on topic LinuxCNC Does not recognize THC
I walked away from it last night and started again this morning and now it seems to be working fine. Not sure what changed, I didn't do anything to the machine other than let it sit overnight.
23 Oct 2020 22:23 #187042 by rodw
Replied by rodw on topic LinuxCNC Does not recognize THC
That is the way to do it. The number of times I do that and the solution comes to me as I go to bed or as I wake up!
23 Oct 2020 22:28 #187044 by phillc54
Yep, happens all the time. :)
24 Oct 2020 07:54 #187072 by tommylight
Gremlins ! :)
Time to create page: 0.388 seconds
