valid arc lost program is paused
- shizyo
28 Jan 2021 03:56 #196891
by shizyo
Replied by shizyo on topic valid arc lost program is paused
So you mean editting the torch off before end path rule in the plasmac.tools file, not the post processor file? I am sorry to ask but how I can do it?
- phillc54
- Thank you received: 2100
28 Jan 2021 04:27 #196892
by phillc54
Replied by phillc54 on topic valid arc lost program is paused
Sorry, I cannot help at the moment, my SheetCam tried to update itself and now it is trashed...
- phillc54
28 Jan 2021 05:48 #196898
by phillc54
A couple of different things you could try from
this pic
you posted:
#1: in the left hand image for the torch enable rule check the include leadout box not for torch disable
if that doesn't work, try:
#2: don't enable the overcut in the right hand image
Either one may or may not work, I cannot test it here.
The following user(s) said Thank You: shizyo
- shizyo
28 Jan 2021 08:21 #196907
by shizyo
I tried the #1 and it WORKS like a charm. I admire your attention to details! I appreciate your help alot. Thanks and have a good night!
- Ekholm
- Thank you received: 12
21 May 2023 07:55 #271804
by Ekholm
Replied by Ekholm on topic valid arc lost program is paused
Hi! I have a similar problem. My problem is when the cut is finished and the part falls away my arc ok will halt. Can I pause the arc ok for the last couple of mm? I also have sheetcam. I heard that I should avoid having lead outs and that I shouldn’t look into this. But I heard that I could have rounder holes if I use overcut and therefore want my machine to ignore the last mm of arc ok. Is there a command for ignoring arc ok?
- snowgoer540
- Thank you received: 907
21 May 2023 19:46 #271872
by snowgoer540
Replied by snowgoer540 on topic valid arc lost program is paused
I believe you are looking for this:
linuxcnc.org/docs/devel/html/plasma/qtpl...html#_lost_arc_delay
If you have a newer config, it's pre-populated, but commented out in custom.hal. The default is 0.0s so do change it. I have been using 0.1s without incident for quite some time.
Time to create page: 0.269 seconds
