valid arc lost program is paused
5 years 9 months ago #196898 by phillc54
A couple of different things you could try from this pic you posted:
#1: in the left hand image for the torch enable rule check the include leadout box not for torch disable
if that doesn't work, try:
#2: don't enable the overcut in the right hand image
Either one may or may not work, I cannot test it here.
The following user(s) said Thank You: shizyo
5 years 9 months ago #196907 by shizyo
I tried the #1 and it WORKS like a charm. I admire your attention to details! I appreciate your help alot. Thanks and have a good night!
3 years 5 months ago #271804 by Ekholm
Hi! I have a similar problem. My problem is when the cut is finished and the part falls away my arc ok will halt. Can I pause the arc ok for the last couple of mm? I also have sheetcam. I heard that I should avoid having lead outs and that I shouldn’t look into this. But I heard that I could have rounder holes if I use overcut and therefore want my machine to ignore the last mm of arc ok. Is there a command for ignoring arc ok?
3 years 5 months ago #271872 by snowgoer540
I believe you are looking for this:
linuxcnc.org/docs/devel/html/plasma/qtpl...html#_lost_arc_delay
If you have a newer config, it's pre-populated, but commented out in custom.hal.  The default is 0.0s so do change it.  I have been using 0.1s without incident for quite some time.
