valid arc lost program is paused
5 years 9 months ago #196875 by shizyo
Thanks for the reply but I tried that(arc-lost-delay 0.3) and add the debounce as well as mentioned in the first post but it didn't help. I also tried to change from Mode 1 to Mode 0 but same result. My problem is if I use M62 P3 command, I will get the error message. Is there anything else you want me to try?
5 years 9 months ago #196877 by phillc54
I "think" the problem is that you disable the torch, move a short distance then enable the torch again before moving again. It would most probably error when you enable the torch again as the should be no Arc OK signal. For example in the square:
m62p3 (Torch Disable) (Before end) g1x37.223y55.400 m63p3 (Torch Enable) (Before end) g1x39.723y55.400
5 years 9 months ago #196889 by shizyo
You are right! I moved the line "m63 p3" to the end of the file and no more the valid arc lost error message. So that means I need to modify a Gcode file manually every time I run it? Is there any way to do it automatically by adjusting somthing in Sheetcam or the post processor?
5 years 9 months ago #196890 by phillc54
You would need to edit the rules so that the torch turned back on after the last move.
5 years 9 months ago #196891 by shizyo
So you mean editting the torch off before end path rule in the plasmac.tools file, not the post processor file? I am sorry to ask but how I can do it?
5 years 9 months ago #196892 by phillc54
Sorry, I cannot help at the moment, my SheetCam tried to update itself and now it is trashed... :(
Time to create page: 0.359 seconds
