Want to test MPG
5 years 7 months ago #200816 by tecno
xhc-whb04b-6 -ue looks not OK. Is it so that the line: pndnt wheel total counts {counts=0 activeCounter=0 isLeadActive=0}
Should the counts=0 be counting up or not?
If yes I really start to suspect that the driver is not working with this USB cable connected XHC-LHB04-6
5 years 7 months ago #200821 by tecno
Can somebody with a WHB04-6 with RF/WiFi run tis test and show results
xhc-whb04b-6 -ue
5 years 7 months ago #200829 by alkabal
We can suspect your wheel is not managed exactly like the rf version.
5 years 7 months ago #200833 by tecno
the numbers you refer to are counting. But not the Yellow in my picture.
So in that case my wheel is OK
5 years 7 months ago - 5 years 7 months ago #200840 by crowloy
Replied by crowloy on topic Want to test MPG
I've done some more testing including turning on verbose. Here are the results loadrt or2 is completely ignored in place of the loadrt or2 names= line causing the addf or2.in0 to fail later on.
wopass: loadrt pid names=pid.x,pid.y,pid.y2,pid.z,pid.s twopass: loadrt or2 names=pendant:run_or2,pendant:pause_or2,pendant:resume_or2,pendant:stop_or2,pendant:jog_speed_or2 twopass: loadrt plasmac twopass: loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok twopass: loadrt ilowpass names=pendant:mpg_ilowpass,pendant:mpg_height-ovr twopass: loadrt mult2 names=pendant:jog_mult2 twopass: loadrt mux2 names=pendant:jog_enable_mux twopass: loadrt flipflop names=pendant:run_ff,pendant:pause_ff,pendant:resume_ff twopass: loadrt toggle names=pendant:power-button_toggle twopass: loadrt toggle2nist names=pendant:power-machine_toggle twopass: pass0:END twopass: pass1:BEGIN twopass: sourcing: /tmp/tmp_plasmanew.hal HAL: ERROR: function 'or2.0' not found twopass: Error in file ./plasmanew.hal: addf failed twopass: sourcing: ././plasmac/plasmac.tcl twopass: sourcing: /tmp/tmp_plasmanew_connections.hal twopass: sourcing: /tmp/tmp_pendant.hal
I changed the loadrt or2 to loadrt or2 names=or2.0 and that works as it should and linuxcnc runs. so for some reason, with multiple lines of or2, you need to name them or they are ignored. I do not know if it's only because one set is named or not.
Last edit: 5 years 7 months ago by crowloy.
5 years 7 months ago - 5 years 7 months ago #200862 by alkabal
Have you try to push continuous or step button before moving the wheel ?
In your picture i see only 00 00 for the wheel value
Last edit: 5 years 7 months ago by alkabal.
Time to create page: 0.524 seconds
