Want to test MPG
- tecno
- Thank you received: 127
20 Feb 2021 13:17 - 20 Feb 2021 13:29 #199525
by tecno
Want to test MPG was created by tecno
Hi guys,
Just received my WHB04-6 MPG that is wire connected.
Testing OK as standalone but nothing in LCNC = shows Lost RF but this is not wireless MPG
Any hints of what might be wrong?
Has anybody made a fancy HAL with bells and whistles for plasmaC + Gmoccapy?
Cheers
Bengt
[HAL]
# required
TWOPASS = ON
# the base machine
HALFILE = tecnoplasma.hal
# the plasmac component connections
HALFILE = plasmac.tcl
# the plasmac machine connections
HALFILE = tecnoplasma_connections.hal
# WHBO4 MPG
xhc_whb04b_6.hal
# use this for customisation after GUI has loaded
POSTGUI_HALFILE = postgui.hal
# required
HALUI = haluiTesting OK as standalone but nothing in LCNC = shows Lost RF but this is not wireless MPG
Cheers
Bengt
Last edit: 20 Feb 2021 13:29 by tecno. Reason: edited text
- aleksamc
- Thank you received: 67
20 Feb 2021 19:21 #199551
by aleksamc
Replied by aleksamc on topic Want to test MPG
I didn't have experiance with this type of MPG, but have you seen this
manual
The following user(s) said Thank You: tecno
- tecno
20 Feb 2021 20:18 - 20 Feb 2021 20:19 #199555
by tecno
Replied by tecno on topic Want to test MPG
UDEV was missing and some editing within xhc-whb04b-6 halfile and the MPG is up and running.
# WHBO4 MPG
xhc_whb04b_6.hal
HALFILE = was missing
Above on my laptop SIM GMOCCAPY
My RPi4 suddenly it does not boot
# WHBO4 MPG
xhc_whb04b_6.hal
Last edit: 20 Feb 2021 20:19 by tecno.
- tecno
21 Feb 2021 19:07 #199643
by tecno
So I managed to get boot functioning on the RPi4
But nothing works on the MPG with PlasmaC.
Anybody having this type of MPG working with PlasmaC willing to share suitable halfile?
I do believe my new USB thumb memory said not to be Linux compatible might have caused the SSD boot havoc, the whole system freezes kind of and nothing works.
- phillc54
- Thank you received: 2100
22 Feb 2021 07:03 #199681
by phillc54
Replied by phillc54 on topic Want to test MPG
You will probably need to rearrange some hal logic to suit the pendant.
I use a XHC-HB04 so I don't know if this will be any help but my hal file is attached.
The following user(s) said Thank You: crowloy
- tecno
22 Feb 2021 13:16 #199702
by tecno
Am getting closer but looks like ./plasma_table.ini is missing
Cheers
Bengt
Cheers
Bengt
- tecno
22 Feb 2021 14:19 #199708
by tecno
Here errors I get now, beginning to think that RF and FIXED cable variants are not the same. I hope I am wrong
pi@pi4-mate:~ $ linuxcnc
LINUXCNC - 2.8.1-57-gdca6f8d05
Machine configuration directory is '/home/pi/linuxcnc/configs/tecnoplasma'
Machine configuration file is 'tecnoplasma.ini'
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./tecnoplasma.hal
twopass:found ././plasmac/plasmac.tcl
twopass:found ./tecnoplasma_connections.hal
twopass:found ./pendant.hal
twopass:pass0: loadusr -W xhc-hb04 -I ./tecnoplasma.ini -H -x -s 1
xhc-hb04: waiting for XHC-HB04 device
Waiting for component 'xhc-hb04' to become ready.....................xhc-hb04: waiting for XHC-HB04 device (5)
..........xhc-hb04: waiting for XHC-HB04 device (6)
.........xhc-hb04: waiting for XHC-HB04 device (7)
..........xhc-hb04: waiting for XHC-HB04 device (8)
..........xhc-hb04: waiting for XHC-HB04 device (9)
..........xhc-hb04: waiting for XHC-HB04 device (10)
..........xhc-hb04: waiting for XHC-HB04 device (11)
xhc-hb04: MAX_WAIT_SECS exceeded, exiting
twopass: Error in file ./pendant.hal:
waitpid failed xhc-hb04 xhc-hb04
xhc-hb04 exited without becoming ready
Note: Using POSIX realtime
LinuxCNC terminated with an error. You can find more information in the log:
/home/pi/linuxcnc_debug.txt
and
/home/pi/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
pi@pi4-mate:~ $ Please Log in or Create an account to join the conversation.
- tecno
22 Feb 2021 16:04 - 22 Feb 2021 16:21 #199718
by tecno
Replied by tecno on topic Want to test MPG LHB04-6
To straighten up my MPG model is LHB04-6
So is it so that I need yet another hal-file for this pendant?
forum.linuxcnc.org/24-hal-components/378...lved?start=50#157515
Is this compiled to the existing HB04-6 ??
Last edit: 22 Feb 2021 16:21 by tecno.
- tecno
22 Feb 2021 20:18 - 22 Feb 2021 21:17 #199761
by tecno
Edit//
# default function button signals WORKING
net pdnt.button.m-home whb.button.m-home halui.home-all # Homing use built-in halui home all
# axis position related signals feedback WORKING
net pdnt.axis.x.pos-feedback halui.axis.x.pos-feedback whb.halui.axis.x.pos-feedback
net pdnt.axis.y.pos-feedback halui.axis.y.pos-feedback whb.halui.axis.y.pos-feedback
net pdnt.axis.z.pos-feedback halui.axis.z.pos-feedback whb.halui.axis.z.pos-feedback
Edit//
Last edit: 22 Feb 2021 21:17 by tecno. Reason: New files inserted
- tecno
23 Feb 2021 11:51 #199813
by tecno
What am I missing ?
TEST MPG HAL just to see that I can select axis
LCD get updated so this code works
HAL
loadusr -W xhc-whb04b-6 -HfsB
# ABSOLUTE POSITION LCD
net pdnt.pos-x halui.axis.x.pos-feedback => whb.halui.axis.x.pos-feedback
net pdnt.pos-y halui.axis.y.pos-feedback => whb.halui.axis.y.pos-feedback
net pdnt.pos-z halui.axis.z.pos-feedback => whb.halui.axis.z.pos-feedback
Using AXIS and I can not select axis.
# "selected axis" signals
net pdnt.axis.x.select whb.halui.axis.x.select => halui.axis.x.select halui.joint.0.select
net pdnt.axis.y.select whb.halui.axis.y.select => halui.axis.y.select halui.joint.1.select
net pdnt.axis.Z.select whb.halui.axis.z.select => halui.axis.z.select halui.joint.2.select HAL
# Joint 0
# axis enable chain
newsig emcmot.0.enable bit
sets emcmot.0.enable FALSE
net emcmot.0.enable <= joint.0.amp-enable-out
net emcmot.0.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.00.enable pid.0.enablePlease Log in or Create an account to join the conversation.
Time to create page: 0.319 seconds
