- Thank you received: 2100
No, the code had a bug that assumed the Torch Pulse button was existing even if it wasn't.Nick7251 wrote:
phillc54 wrote: I can emulate that error here, I have pushed a fix for it.
It is from not having a Torch Pulse button or maybe the code for the TP button in the ini file is not quite correct.
It should be something like:Code:BUTTON_n_CODE = torch-pulse 0.5
Looks like I was wrong. I did have torch pulse enabled, but I must have turned it back off at some point.
So this problem is because it is looking torch pulse to be enabled?
If you put the correct torch pulse code in your ini file that will fix it for you until LinuxCNC is updated.
