- Thank you received: 907
Nick7251 wrote: ........ You can duplicate this by removing your ground clamp and running a job. ,.........
my 2 pence / 2 cents....
when you remove the plasma clamp (it's actually + / positive with respect to the torch, the torch is - / negative polarity)
you are forcing the torch to use its High Frequency circuit to maintain the plasma arc ..... hence in my opinion you have an electrical noise problem which is causing a spike and upsetting Comms...... are you using a shared earth and zero volt connection?
you use of the word "ground" has me worried as many don't understand what ground, earth, and zero volt are and that there is a difference
