plasmac error
03 Apr 2021 23:38 #204686 by phillc54
Replied by phillc54 on topic plasmac error
Something like below, changing pin names and delay to suit:
loadrt dbounce names=db_z_pos_lim
addf db_z_pos_lim servo thread
setp db_z_pos_lim.delay 3
net z_pos_lim_raw hm2_7i96.0.gpio.000.in => db_z_pos_limit.in
net z_pos_lim db_z_pos_lim.out => joint.3.pos-lim-sw-in
linuxcnc.org/docs/devel/html/man/man9/dbounce.9.html
03 Apr 2021 23:44 #204687 by motal2004
Replied by motal2004 on topic plasmac error
Would this me in my connection hal file Or the regular hal file?
03 Apr 2021 23:47 #204689 by phillc54
probably in your regular hal file, there will be existing connections there you need to break.
03 Apr 2021 23:57 #204692 by motal2004
the breaks sound like fun times
04 Apr 2021 02:01 - 04 Apr 2021 02:01 #204702 by motal2004
any one willing to help me here with the dbounce i tried and keep getting error, here is my hal file
File Name: m6.hal
File Size:11 KB
please and thank you
Last edit: 04 Apr 2021 02:01 by motal2004.
04 Apr 2021 02:03 #204703 by phillc54
What is the error message?
04 Apr 2021 02:20 - 04 Apr 2021 22:52 #204705 by phillc54
Try this:
# --- MAX-HOME-Z ---
#net max-home-z     <=  hm2_7i96.0.gpio.037.in_not
loadrt dbounce names=db_max-home-z
addf db_max-home-z servo-thread
setp db_max-home-z.delay 3
net max-home-z_raw hm2_7i96.0.gpio.037.in => db_max-home-z.in
net max-home-z <= db_max-home-z.out
Last edit: 04 Apr 2021 22:52 by phillc54. Reason: code typo, servo thread should be servo-thread, thanks PCW
04 Apr 2021 17:54 #204792 by motal2004
i get this error
hm2/hm2_7i96.0: IO Pin 050 (P1-25): IOPort
hm2/hm2_7i96.0: registered
HAL: ERROR: bad position: 0
twopass: Error in file ./m6.hal:
addf failed
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Note: Using POSIX realtime
LinuxCNC terminated with an error. You can find more information in the log:
/home/cnc/linuxcnc_debug.txt
and
/home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
04 Apr 2021 18:01 #204794 by PCW
Replied by PCW on topic plasmac error
addf db_max-home-z servo thread
should probably be
04 Apr 2021 18:09 - 04 Apr 2021 18:16 #204796 by motal2004
that work. linuxcnc complies and opens up. Now i get this error
joint 3 on limit switch error
emc/task/taskintf.cc 947: Error on joint 3, command number 166
/usr/lib/python2.7/dist-packages/gmoccapy/notification.py:168: GtkWarning: Invalid icon size 48
self.popup.show()
i had a typo in my hal file
Last edit: 04 Apr 2021 18:16 by motal2004.
Time to create page: 0.165 seconds
