User Interfaces
Plasmac
THCAD-10 configuration, QtPlasmaC
Thank you received: 7487
18 Apr 2021 10:09 #206287
I guess I should probably try to get a reed relay and fix an ARC OK signal as well, but eager to get it working
Some plasma cutters just don't work with the soft arc ok, the reed is very reliable.
I have several machines using soft arcok by now with no issues at all, so i think the failures are caused by interference and bad grounding/shielding.
Also, on HF/HV pilot arc plasma sources, the spark gap can cause the lost arc, making the gap just a tiny bit smaller fixes that.
User Interfaces
Plasmac
Time to create page: 0.111 seconds
