Start in Fullscreen Mode
  • AgentWD40
  • AgentWD40's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 Apr 2021 16:52 #206419 by AgentWD40
Start in Fullscreen Mode was created by AgentWD40
I've been tinkering with my startup and have it working where xfce automatically logs in and starts linuxcnc (qtplasmac) in full screen mode.
I finally managed to get auto fullscreen using a 3rd part app called devilspie2. But I can't help but wonder, is there an easier way? A way that doesn't involve running another service in the background...
Finally, is there a way to make sure the linuxcnc window loads before the desktop and it's icons load? Just to keep the user from clicking around before linuxcnc loads. This is not a big deal at all, it would just be convenient.
(testing with the current linuxcnc debian iso + linuxcnc 2.9)
19 Apr 2021 18:05 #206437 by tommylight
Replied by tommylight on topic Start in Fullscreen Mode
QTPlasmaC on Mint 19.3, i maximise it once on a 1920X1200 monitor and it starts maximised after that. Never needed to do anything.
  • AgentWD40
  • Platinum Member
  • Platinum Member
19 Apr 2021 18:23 #206442 by AgentWD40
Replied by AgentWD40 on topic Start in Fullscreen Mode
Not maximized but fullscreen. To see what I mean press Alt+F11 while the QTPlasmaC window has focus.
19 Apr 2021 20:07 #206467 by tommylight
Oh that, it does not work for me here on Mint 19.3
19 Apr 2021 20:11 #206468 by bevins
Replied by bevins on topic Start in Fullscreen Mode
Doesnt work for me either. Linux Mint 19.3
  • AgentWD40
  • Platinum Member
  • Platinum Member
19 Apr 2021 20:24 - 19 Apr 2021 20:27 #206471 by AgentWD40
It depends on what desktop your running.
xfce = Alt+F11
Cinnamon = F11 or Alt+F12 or maybe not setup by default
Mate = disabled by default
Anyway. I'm setting up for a default linuxcnc iso install with xfce.
fullscreen is much cleaner than maximized.
VS
I gained 2 rows of buttons!
Last edit: 19 Apr 2021 20:27 by AgentWD40.
19 Apr 2021 21:54 #206481 by cmorley
Replied by cmorley on topic Start in Fullscreen Mode
Try something similar to this in the INI:
DISPLAY = qtvcp -f qtplasmac
The following user(s) said Thank You: AgentWD40
19 Apr 2021 22:08 - 19 Apr 2021 22:39 #206483 by snowgoer540
Replied by snowgoer540 on topic Start in Fullscreen Mode
That works here on MX Linux VirtualBox. But it doesnt take focus, the taskbar is on top of it.
EDIT: Works fine on my actual table.
Last edit: 19 Apr 2021 22:39 by snowgoer540.
19 Apr 2021 22:53 #206484 by snowgoer540
Curious: how do you plan to have the user exit/shutdown?
  • AgentWD40
  • Platinum Member
  • Platinum Member
19 Apr 2021 23:20 - 19 Apr 2021 23:25 #206485 by AgentWD40
Haven't gotten there yet. My first thought is just use one of the customizable buttons to run a script. Ideally the shutdown button would be on another tab though... I need to consider it getting fat fingered. Maybe even a physical button wired in to an input.
It's been a while but I thought it was the original gui concept designer's intention to run this full screen. Did that change or just get overlooked?
Last edit: 19 Apr 2021 23:25 by AgentWD40.
Time to create page: 0.124 seconds
