problen with debounce on sensor
24 Apr 2021 13:23 #206951 by Clive S
problen with debounce on sensor was created by Clive S
I am have a problem with the syntax with the debounce names type
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok,db_x-home,db_y-home,db_y2-home,db_z-home
addf db_x-home servo-thread
net home-x db_x-home.in
net home-x-out db_x-home.out
Setp !!!!
# --- HOME-X ---
net home-x <= hm2_7i96.0.gpio.001.in
How do I setup debouce
24 Apr 2021 14:09 - 24 Apr 2021 14:09 #206952 by PCW
Replied by PCW on topic problen with debounce on sensor
setp db_x-home.delay 25
net raw-home-x hm2_7i96.0.gpio.001.in db_x-home.in
net home-x db_x-home.out
Last edit: 24 Apr 2021 14:09 by PCW.
24 Apr 2021 17:54 #206961 by Clive S
Replied by Clive S on topic problen with debounce on sensor
Thanks Peter.
I could do it in 2.8 but not in 2.9 with the names variety. To me the docs are not clear.
I will give it a go i;n the morning
25 Apr 2021 18:29 #207035 by Clive S
Yes. It loads without errors. How can I check to see if it is actually working . IE how would I check lt in Halshow.
Many thanks.
25 Apr 2021 19:51 - 25 Apr 2021 19:52 #207038 by snowgoer540
Replied by snowgoer540 on topic problen with debounce on sensor
Because the debounce time is usually so small, you probably won’t be able to notice it with Hal show.
You would be better watching this in halscope.
You could watch the db-xhome.in or the input pin itself and db-xhome.out. The output should be delayed by the time you have it debounced for.
Last edit: 25 Apr 2021 19:52 by snowgoer540.
25 Apr 2021 21:03 #207041 by Clive S
Greg. I think it would be good if there was an example in the docs for QTPasmaC it does mention debounce but not how to achieve it.
The docs for 2.9 don't really cover the situation when using debounce using "names"
25 Apr 2021 21:28 - 26 Apr 2021 02:34 #207042 by snowgoer540
I will look into seeing if there’s room to clarify what’s there a bit, and maybe post a link to the proper manual if it’s not there.
In the meantime did you check this one out:
linuxcnc.org/docs/html/man/man9/dbounce.9.html
It’s a bit tough to find because dbounce and debounce are really close, google serves up the wrong one.
Edit: The docs read ok to me. There is also already a link to the dbounce docs in the debounce area of the qtplasmac user guide. I think the confusion is that google serves up the wrong doc because it thinks it should be spelled “debounce”. At any rate, I think specific examples for debouncing limit switch, etc. would be outside the scope of the qtplasmac docs.
Last edit: 26 Apr 2021 02:34 by snowgoer540.
26 Apr 2021 06:00 #207079 by Clive S
Yes . I did find both versions in the docs. You are probably correct re the QTplasmaC docs .
This line
If debounce is required for other equipment like home or limit switches etc then more dbounce components may added in any of the HAL files without any regard to the signals listed here.
changes from debounce to dbounce
This is what was generated with my version of QTplasmaC
# ---PLASMA INPUT DEBOUNCE---
#values for these are in custom.hal ... but there was nothing generated in the custom hal
addf db_float servo-thread
addf db_ohmic servo-thread
addf db_breakaway servo-thread
addf db_arc-ok servo-thread
So I could not find the values anywhere, nor could I understand how to do it. The good thing is I learnt a lot .:)
I do appreciate all the help
26 Apr 2021 11:23 #207100 by snowgoer540
This line
That seems right to me. The first mention is talking about debouncing a switch, and the second is referring to the component "dbounce".
How long ago did you make your config? I had a few backups people have posted on here over the last few weeks, only one of them had this stuff in custom.hal:
# for the float and ohmic inputs each increment in delay is
# is a 0.001mm (0.00004") increase in any probed height result
setp db_float.delay     5
setp db_ohmic.delay     5
setp db_breakaway.delay 5
setp db_arc-ok.delay    5
So either they took them out, or they aren't always getting put in for some reason. One reason I can see is if custom.hal already existed, but had nothing in it, it would not get that extra stuff. I am not sure in what cases this could be true, but from my 10s of looking at it, that's what I saw.
I will try to remember to check it out after work, but Phill might have to take a peek when he's back from vacation, and see if anything fishy is up.
26 Apr 2021 11:52 #207104 by Clive S
This line
I have only been playing with QTplamaC for a short time. So I believe I started with a new config.
In any event a custom.hal file should never get updated. Unless I suppose just once with a clean config.
If I had seen the above it would have been simple B)
Thanks.
Time to create page: 0.824 seconds
