Hypersense configuration with 2.8 and PlasmaC
- txtrone
- Thank you received: 106
04 May 2021 19:34 #207866
by txtrone
Hypersense configuration with 2.8 and PlasmaC was created by txtrone
I cannot get Hypersense to work. Not sure what I have done or not done. The screen caps are with the torch not touching the plate and then with torch touching. Also including my ini hal and hal connections.
- Thank you received: 5330
04 May 2021 20:41 #207869
Replied by PCW on topic Hypersense configuration with 2.8 and PlasmaC
Could be a wiring issue.
If you simply short the two sense wires do you get close to 0V
on ohmicsense.ohmic-volts?
- Thank you received: 4150
04 May 2021 21:06 #207871
Replied by rodw on topic Hypersense configuration with 2.8 and PlasmaC
I'm thinking some crap is in the nozzle shorting it out. Can you remove the consumables and give it a clean out in there?
There is a near full voltage when off the plate so as PCW says, there is s short somewhere.
The following user(s) said Thank You: txtrone
04 May 2021 21:31 - 04 May 2021 21:31 #207875
Ahh I had forgotten it reads high (~24V) when shorted
so yeah either a short or the sense load resistor is missing
or misconnected
or misconnected
Last edit: 04 May 2021 21:31 by PCW.
- txtrone
04 May 2021 21:53 #207877
by txtrone
That makes sense! (pun intended) ... but this is a two part problem.
Before I left the shop for the day I tried unplugging the sense cable from the torch and the reading dropped to near zero. So you are probably correct about the short being caused by "crap in the nozzle". I made some simple cuts this weekend, mainly to test the downdraft, and must have gotten said crap in the nozzle.
HOWEVER (part two)
The ohmic signal is not on in the GUI... and I do not recall seeing it on. I believe I have the wiring correct, but never connected all of the HAL/Plasmac pins properly.
Replied by txtrone on topic Hypersense configuration with 2.8 and PlasmaC
HOWEVER (part two)
- snowgoer540
- Thank you received: 907
04 May 2021 21:59 #207879
by snowgoer540
You would have to press "OHMIC TEST" to see the Ohmic Probe indicator light up on the GUI.
Replied by snowgoer540 on topic Hypersense configuration with 2.8 and PlasmaC
- txtrone
04 May 2021 22:00 #207880
by txtrone
Correct. I failed to mention I pressed the OHMIC TEST button, nothing lit up on the GUI.
- Thank you received: 7488
04 May 2021 23:08 #207894
Replied by tommylight on topic Hypersense configuration with 2.8 and PlasmaC
Just to be sure, does the torch have an electrode, a nozzle and a shield ?
04 May 2021 23:23 #207898
What is the pin that enables Ohmic sensing so the probe becomes active?
I suspect that Plasmac has changed since the component has been written or we got something wrong in the connections file.
the component will only go true if ohmicsense.is-probing is true
se lets setp it to 1 for now
- phillc54
- Thank you received: 2100
04 May 2021 23:25 #207899
by phillc54
Replied by phillc54 on topic Hypersense configuration with 2.8 and PlasmaC
The same one it has always been, plasmac.ohmic-enable
Time to create page: 0.333 seconds
