Help install "QtPlasmac" !!
- Aqeel
07 May 2021 04:02 #208178
by Aqeel
Help install "QtPlasmac" !! was created by Aqeel
- thefabricator03
- Visitor
07 May 2021 05:45 #208181
by thefabricator03
Replied by thefabricator03 on topic Help install "QtPlasmac" !!
We need a bit more information if we are to help, what have you tried? What exactly are you having trouble with?
- Thank you received: 7476
07 May 2021 08:00 #208184
Replied by tommylight on topic Help install "QtPlasmac" !!
Using a sim will not control the machine, it is for testing software only.
Find the created config directory, there is a file with .ini extension, right click on it and choose "open with other app" or similar, then type "linuxcnc" in the box and press enter.
The following user(s) said Thank You: Aqeel
- snowgoer540
- Thank you received: 903
07 May 2021 09:48 #208195
by snowgoer540
Replied by snowgoer540 on topic Help install "QtPlasmac" !!
You also really need to update. You are on a really old version. Current qtplasmac version is 1.0.31
Have you given the user guide a good read/follow: linuxcnc.org/docs/devel/html/plasma/qtplasmac.html
- Aqeel
07 May 2021 18:54 #208243
by Aqeel
Replied by Aqeel on topic Help install "QtPlasmac" !!
I've tried the "axis" interface and it works, all drives are working properly, and I'm using a breakout board control.
The problem is when I want to work on one of the other graphical interfaces such as "qtplasma", it does not work because there are settings in "ini, hal" files and I face many problems because I am not an expert in "linux" systems.
- Aqeel
07 May 2021 19:13 #208245
by Aqeel
I have tried but a lot of bugs appear
Please can you access a remote device?
And looking at my system files?
- Aqeel
07 May 2021 19:15 #208246
by Aqeel
There are a lot of details and I do not understand them
If you can help me
Will I send the access data to my remote device?
If you can help me
- Aqeel
07 May 2021 19:16 #208247
by Aqeel
The picture that appears in the post is not from my device, but is for illustration only
- Aqeel
07 May 2021 19:25 #208249
by Aqeel
I did not find this file through which I can configure my machine to run with the "qtplasmac" interface
07 May 2021 20:19 #208257
More info and screenshots/files of the errors you are getting, otherwise we are unable to help.
What plasma? What Linux? Version of LinuxCNC? everything...
Time to create page: 0.138 seconds
