Torch will not Fire
- phillc54
- Thank you received: 2100
16 May 2021 07:09 #209048
by phillc54
Replied by phillc54 on topic Torch will not Fire
+1
I think the torch is trying to be turned on and is then turned off by Plasmac for some reason.
If that were the case then it should give a lost arc error. Apparently there are no error messages.
Strange, if air starts to flow the torch had to be triggered.
- Thank you received: 4151
16 May 2021 07:25 - 16 May 2021 07:28 #209050
If there was an issue in the torch, the parts in place error would not allow air flow.
The only other possible issue is poor connection on the high voltage side. Torch connections, ground clamp etc. But in my experience, Plasmac would report a fault as you state.
Manually short the relevant torch on pins (1&2 from an earlier thread) to see if it fires.
Replied by rodw on topic Torch will not Fire
+1
Last edit: 16 May 2021 07:28 by rodw.
- Thank you received: 7488
16 May 2021 11:53 #209079
Replied by tommylight on topic Torch will not Fire
Press F9 on the keyboard, wait for at least 60 seconds, press F9 again.
Report exactly what is happening.
- bevins
- Thank you received: 338
16 May 2021 14:47 - 16 May 2021 14:49 #209098
by bevins
What is it with you and F9?
WTF does F9 do?
/EDIT AH! I found it....
Replied by bevins on topic Torch will not Fire
WTF does F9 do?
Last edit: 16 May 2021 14:49 by bevins.
16 May 2021 16:00 - 16 May 2021 16:02 #209108
Edit after laughing subsided:
It is very useful for testing stuff on plasma cutters and when using run from here.
LOL
WTF does F9 do?
Last edit: 16 May 2021 16:02 by tommylight. Reason: more info
- Hippy
16 May 2021 16:36 #209117
by Hippy
Replied by Hippy on topic Torch will not Fire
Turned off arc-ok....still the same
Think i am down to shorting the torch on/off wires to see if it fires, either that or a sledgehammer.
When i pulse fire it, the readout on the GUI shows like its getting volts. The readout goes from 0 to 24 and back to 0 when the cycle ends. If i have the plasma turned off and pulse fire the readout dont change so it seems to be working right.
So i am thinking Linuxcnc and QTPlasmaC is doing what it's supposed to be doing. Just for some reason my torch is not firing remotely.
So what's the safest way to short the wires to see if it fires?
- Hippy
16 May 2021 16:51 #209124
by Hippy
Ok i shorted the wires, still same thing it clicks air comes out but no fire.
So i can eliminate anything control wise right?
- Hippy
16 May 2021 19:59 #209159
by Hippy
I have fixed it!!! It was something stupid, talked to the guy who built the torch. This torch needed at least 65psi coming out the torch head AND post flow of at least 30 seconds.
- Clive S
- Thank you received: 486
16 May 2021 20:05 #209161
by Clive S
I think Tom surgested it needs at least 6 bar on the first page.
Replied by Clive S on topic Torch will not Fire
16 May 2021 20:16 #209163
He kept ignoring most of what we said, so i stopped bothering.
That has nothing to do with LinuxCNC ...Switched them and now air comes out when i fire the torch but no fire.
-check air pressure, must be 5 to 6 bar <<<<<<<<<
-check and change the consumables, tighten them properly
-check the clamp for good contact with material
-check the plasma source for the state, in test mode it will not work remotely.
Time to create page: 0.149 seconds
