The "THC ACTIVE" indicator is not active.
09 Jun 2021 11:03 #211611 by phillc54
Replied by phillc54 on topic The "THC ACTIVE" indicator is not active.
The ArcVoltage input is a floating point value. Most folk get it by using a Mesa THCAD connected to an encoder and then use the velocity output of the encoder.
Can I enter analog voltage to ArcVoltage after a voltage divider 50: 1 from plasma?
No, you cannot directly input a voltage, it can only be a HAL floating point value.
Why an error in the lower right corner appears - "joint 2 following error"?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Following_Error
Time to create page: 0.254 seconds
