Testing ark voltage Values in qtplamac
- Aussiecrawl
20 Jun 2021 21:57 #212519
by Aussiecrawl
Testing ark voltage Values in qtplamac was created by Aussiecrawl
Easy question, With QTPlasmac will the Arc Voltage read a voltage while it is not cutting.
I'm wanting to double check my wiring and voltage settings are correct. If i put a known source of voltage eg12 volts into the thcad terminals is there anyway to get it to show the voltage while it is not cutting? Im not near my setup during the week and trying to plan ahead for the weekend.
- Thank you received: 7478
20 Jun 2021 22:08 #212522
Replied by tommylight on topic Testing ark voltage Values in qtplamac
Yes it will show the voltage.
- Aussiecrawl
06 Jul 2021 23:02 #213911
by Aussiecrawl
Replied by Aussiecrawl on topic Testing ark voltage Values in qtplamac
Thanks for the reply,
Now that i have everything setup im getting a constant 700v reading even with nothing connected to the Input terminals of the THCad. Im running the thcad300 into a 7i76e and im wondering if its a calculation error with Pncconfig as the online calculator and what comes up in the settings after running through the config are 2 different values.
If i change the values in the settings to what the online calculator says i get 0 volts when there is no voltage but if i put 24 or 48v into the thcad i dont get a change in value shown.
06 Jul 2021 23:38 #213913
Post your config here.
- phillc54
- Thank you received: 2100
07 Jul 2021 00:02 #213917
by phillc54
When you post the config could you also post the .pncconf file that is created for the config in the ~/linuxcnc/configs directory.
Replied by phillc54 on topic Testing ark voltage Values in qtplamac
Thoeretically the online caculator and PnCconf should end up with the same values.Thanks for the reply,
07 Jul 2021 00:34 #213925
0V is ok, not changing the value leads me to believe you have the polarity wrong on the input of the THCAD.
- Aussiecrawl
07 Jul 2021 03:02 #213929
by Aussiecrawl
These are the .hal and .ini files are these the ones you need? and i have attached the PnCconfig file as well
- Aussiecrawl
07 Jul 2021 03:04 #213930
by Aussiecrawl
I did check to see if i had the polarity correct but can double check this.
- phillc54
07 Jul 2021 03:18 #213931
by phillc54
Thanks for the files, it is best to post the file created by the BACKUP CONFIG button in the PARAMETERS tab so we can see the complete configuration.
- Aussiecrawl
07 Jul 2021 03:43 #213932
by Aussiecrawl
Time to create page: 0.216 seconds
