First test cut. No torch on when I run the program.
- Shopro702
20 Sep 2021 16:31 #221232
by Shopro702
First test cut. No torch on when I run the program. was created by Shopro702
Im a first time newb. Been working on this machine for awhile and I am ready to see it cut. I am running it in mode 0. So that is just a pilot arc triggered by the digital out to relay. When I enable the torch then press the torch pulse, the relay clicks over and the torch fires. But when I run a simple circle from the conversational (saved as .ngc and loaded), it just plots the circle but I never hear or see the torch on light. Anything please!
- phillc54
- Thank you received: 2100
20 Sep 2021 18:12 #221233
by phillc54
Replied by phillc54 on topic First test cut. No torch on when I run the program.
I was going to ask the obvious "did you have the torch enabled?" but I see you must have if the torch pulse worked.
Could you post a backup of the config (from the Utilities frame in the Parameters Tab or Setup Tab) plus the ngc file that you used.
The following user(s) said Thank You: Shopro702
- Shopro702
20 Sep 2021 20:31 #221238
by Shopro702
Replied by Shopro702 on topic First test cut. No torch on when I run the program.
Well I am now desparate to get past this probing z problem. I have followed the thread regarding the z axis probing issue but I am still getting the bottom limit reached error.
My .ini Z axis and joint - MIN = 0 | MAX = 50
Probe height - I have tried several numbers
Someone mentioned to touch off. I have tried touching off but am not too sure. A prompt asks for G0 or G54+ others.
I have been at for awhile now!
- phillc54
20 Sep 2021 20:39 #221239
by phillc54
Are you using PlasmaC or QtPlasmaC?
Assuming you are using a float switch then so long as Z MIN_LIMIT is below the slats by more than the Float Travel then it should be OK.
Does the Float LED turn on at all, try manually tripping the float switch during probing and see what happens.
- Shopro702
20 Sep 2021 20:45 - 20 Sep 2021 20:52 #221241
by Shopro702
Using PlasmaC. Should I switch to Qt? I am not using a float switch. I set float travel to 0. Just a Z home switch at the top.
I saw a post where you asked if the float switch light was coming on when crossing material. No light.
Last edit: 20 Sep 2021 20:52 by Shopro702.
- phillc54
20 Sep 2021 20:57 #221242
by phillc54
Well if you are not using a float switch then just substitute ohmic for float in my prevoius post.
Do you have Ohmic Probe Enable in the GUI?
- Shopro702
20 Sep 2021 21:03 - 20 Sep 2021 21:10 #221243
by Shopro702
Ok just enabled ohmic probe...
Would you reference your previous post on the ohmic probe?
Last edit: 20 Sep 2021 21:10 by Shopro702.
- phillc54
20 Sep 2021 22:23 #221247
by phillc54
forum.linuxcnc.org/plasmac/43705-first-t...n-the-program#221239
So it would be:
Assuming you are using a ohmic switch then so long as Z MIN_LIMIT is below the slats by more than the Ohmic Probe Offset then it should be OK.
Does the Ohmic LED turn on at all, try manually tripping the ohmic switch during probing and see what happens.
So it would be:
- Thank you received: 7505
21 Sep 2021 08:33 #221268
Should be min=-50, max=0
Replied by tommylight on topic First test cut. No torch on when I run the program.
- Shopro702
21 Sep 2021 18:30 #221301
by Shopro702
So I do not have an ohmic switch or a probe. I thought I could manually set the height. Do I need to have atleast one?
Time to create page: 0.145 seconds
