First test cut. No torch on when I run the program.
- phillc54
- Thank you received: 2100
21 Sep 2021 18:31 #221302
by phillc54
Replied by phillc54 on topic First test cut. No torch on when I run the program.
Yes, you need at least one for PlasmaC and/or QtPlasmaC.
The following user(s) said Thank You: Shopro702
- Shopro702
21 Sep 2021 18:45 #221303
by Shopro702
Replied by Shopro702 on topic First test cut. No torch on when I run the program.
Thanks. I am cutting pipe that is why I have not considered the probes. It is really a breath of fresh air to recieve support from yall!
- Thank you received: 7505
21 Sep 2021 19:00 #221306
Replied by tommylight on topic First test cut. No torch on when I run the program.
Pipe cutting can in most cases be done without a THC easily, but i would not do it without a float switch or ohmic probe, it just saves a lot of time.
Cutting the same size for long periods, that is OK.
Then again, having both is nice and makes work enjoyable.
- Shopro702
21 Sep 2021 21:54 #221321
by Shopro702
Ok so I wired up a switch to manually close the circuit and connected it to HAL probe-in <= digital.in005. Now I have the probe-in light engaging in the AXIS show HAL configuration. So it flashes when I flip it. But the Ohmic probe indicator at the bottom of the ui (in between THC enabled and float switch) does not flash.
- phillc54
21 Sep 2021 23:13 #221323
by phillc54
It needs to be connected to plasmac.ohmic-probe only.
You can check this by entering man plasmac in a terminal.
- Shopro702
22 Sep 2021 09:59 #221348
by Shopro702
Ok I got it to flash thanks to your guidance. I will test it out around noon. Greetings from Nevada!
- Shopro702
22 Sep 2021 14:37 #221368
by Shopro702
Aha! Success. Thanks guys!
Time to create page: 0.353 seconds
