PlasmaC without THC?
29 Sep 2021 06:21 #221801 by Ekholm
PlasmaC without THC? was created by Ekholm
Hi!
Can you run PlasmaC without a THC? I´m not shore how this works, but what I’m after is that i want the height probing (floating z?) part.
29 Sep 2021 06:25 #221802 by phillc54
Replied by phillc54 on topic PlasmaC without THC?
Sure, you could set the THC to not enabled.
29 Sep 2021 07:04 #221806 by Ekholm
Replied by Ekholm on topic PlasmaC without THC?
I couldn't configure it without a THC? At least with the configurator. I tried to change the modes, but none would work without filling in something
I can provide more infomration when im home from work
  • Moderator
  • Moderator
29 Sep 2021 09:40 #221813 by tommylight
Replied by tommylight on topic PlasmaC without THC?
No double posting
already answered on the other thread
The following user(s) said Thank You: Ekholm
29 Sep 2021 12:52 #221827 by Ekholm
Sorry!
30 Sep 2021 05:49 - 30 Sep 2021 05:52 #221867 by Ekholm
"You can use PlasmaC with no THC in mode 2 and by ignoring the ARCOK signal." /TommylightI tried to run the PlasmaC configuration and i didn´t manage to fill it the config without a ARKOK signal. See attached picture. I therefore added a not used input (number 1 in picture). Is that how you ment?The move up and down HAL pins are they necessary? It seems that i can't go through the wizard without those? Sorry for the basic questions!I have tried to look for tutorials but didn´t find what i was looking for. So now i added unused ports and the configuration did go through (but haven’t tested yet)
Last edit: 30 Sep 2021 05:52 by Ekholm.
30 Sep 2021 05:58 #221869 by phillc54
All the entries on the left side are mandatory so you will need to put something in them. After the config is made then you can comment them out in the hal file. You will also need a fake arc-ok signal so you will need to do some editing of the hal file after it is made. When you get all the motion correct and your machine running then post your hal files here and we can help you with the changes required.
30 Sep 2021 06:10 #221870 by Ekholm
Thank you! I really appreciate your help!
  • Moderator
  • Moderator
30 Sep 2021 09:21 #221875 by tommylight
Wire the torch.on pin to arc.ok pin in hal.
06 Oct 2021 06:18 #222332 by Ekholm
This is m HAL file. phillc54 can you help me to do the changes?
_____________________
# Keep your plasmac i/o connections here to prevent them from
# being overwritten by updates or pncconf/stepconf changes
# Other customisations may be placed here as well
# This file is built by the configurator in your configuration directory
#***** DEBOUNCE FOR THE INPUTS *****
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float servo-thread
addf db_ohmic servo-thread
addf db_breakaway servo-thread
addf db_arc-ok servo-thread
# for the float and ohmic inputs
# each increment in delay is a 0.001mm (0.00004") increase in any probed height result
setp db_float.delay 5
setp db_ohmic.delay 5
setp db_breakaway.delay 5
setp db_arc-ok.delay 5
#***** ARC VOLTAGE LOWPASS FILTER *****
# set the cutoff frequency if required
setp plasmac.lowpass-frequency 0
#***** THE JOINT ASSOCIATED WITH THE Z AXIS *****
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
#***** PLASMA CONNECTIONS *****
net plasmac:arc-ok-in hm2_7i96.0.gpio.008.in => db_arc-ok.in
net plasmac:float-switch hm2_7i96.0.gpio.005.in => db_float.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => db_breakaway.in
# net plasmac:ohmic-probe {YOUR OHMIC PROBE PIN} => db_ohmic.in
# net plasmac:ohmic-enable plasmac.ohmic-enable => {YOUR OHMIC ENABLE PIN}
net plasmac:torch-on => hm2_7i96.0.ssr.00.out-00
net plasmac:move-up hm2_7i96.0.gpio.006.in => plasmac.move-up
net plasmac:move-down hm2_7i96.0.gpio.007.in => plasmac.move-down
#***** MULTIPLE TOOL ENABLE *****
# set to 1 to enable a scribe or spotting
setp plasmac.multi-tool 0
#***** SCRIBE CONNECTIONS *****
# net plasmac:scribe-arm plasmac.scribe-arm => ***YOUR_SCRIBE_ARMING_OUTPUT***
# net plasmac:scribe-on plasmac.scribe-on => ***YOUR_SCRIBE_ON_OUTPUT***
Time to create page: 0.133 seconds
