PlasmaC without THC?
06 Oct 2021 01:57 #222335 by phillc54
Replied by phillc54 on topic PlasmaC without THC?
This should be OK, you may need to experiment with Pierce Delay to make sure the arc is fully established before motion starts.
File Name: ekholm.hal
File Size:2 KB
The following user(s) said Thank You: Ekholm
09 Oct 2021 13:00 - 09 Oct 2021 13:13 #222670 by Ekholm
Replied by Ekholm on topic PlasmaC without THC?
Now i have a big problem. I deleted the old PlasmaC folder to make a new (i made changes in the base configuration). Now when  run the configurator (python /usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/configurator.py) the HAL file is totaly different and i can't find the values. What is wrong?! now the hal-file looks like this. I’m probably looking in the wrong place :)
# Generated by PNCconf at Sun Oct  3 19:42:19 2021
# Using LinuxCNC version:  2.8
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp    hm2_7i96.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.y2,pid.z,pid.s
addf hm2_7i96.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.y2.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_7i96.0.write         servo-thread
# external output signals
# external input signals
# --- HOME-X ---
net home-x     <=  hm2_7i96.0.gpio.000.in_not
# --- HOME-Y ---
net home-y     <=  hm2_7i96.0.gpio.001.in_not
# --- HOME-Y2 ---
net home-y2     <=  hm2_7i96.0.gpio.002.in_not
# --- HOME-Z ---
net home-z     <=  hm2_7i96.0.gpio.003.in_not
# --- ESTOP-EXT ---
net estop-ext     <=  hm2_7i96.0.gpio.004.in_not
#  AXIS X JOINT 0
setp   pid.x.Pgain     [JOINT_0]P
setp   pid.x.Igain     [JOINT_0]I
setp   pid.x.Dgain     [JOINT_0]D
setp   pid.x.bias      [JOINT_0]BIAS
setp   pid.x.FF0       [JOINT_0]FF0
setp   pid.x.FF1       [JOINT_0]FF1
setp   pid.x.FF2       [JOINT_0]FF2
setp   pid.x.deadband  [JOINT_0]DEADBAND
setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp   pid.x.maxerror 0.012700
net x-index-enable  <=> pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-pos-fb        =>  pid.x.feedback
net x-output        <=  pid.x.output
# Step Gen signals/setup
setp   hm2_7i96.0.stepgen.00.dirsetup        [JOINT_0]DIRSETUP
setp   hm2_7i96.0.stepgen.00.dirhold         [JOINT_0]DIRHOLD
setp   hm2_7i96.0.stepgen.00.steplen         [JOINT_0]STEPLEN
setp   hm2_7i96.0.stepgen.00.stepspace       [JOINT_0]STEPSPACE
setp   hm2_7i96.0.stepgen.00.position-scale  [JOINT_0]STEP_SCALE
setp   hm2_7i96.0.stepgen.00.step_type        0
setp   hm2_7i96.0.stepgen.00.control-type     1
setp   hm2_7i96.0.stepgen.00.maxaccel         [JOINT_0]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.00.maxvel           [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= joint.0.motor-pos-cmd
net x-vel-cmd    <= joint.0.vel-cmd
net x-output     <= hm2_7i96.0.stepgen.00.velocity-cmd
net x-pos-fb     <= hm2_7i96.0.stepgen.00.position-fb
net x-pos-fb     => joint.0.motor-pos-fb
net x-enable     <= joint.0.amp-enable-out
net x-enable     => hm2_7i96.0.stepgen.00.enable
# ---setup home / limit switch signals---
net home-x     =>  joint.0.home-sw-in
net x-neg-limit     =>  joint.0.neg-lim-sw-in
net x-pos-limit     =>  joint.0.pos-lim-sw-in
#  AXIS Y JOINT 1
setp   pid.y.Pgain     [JOINT_1]P
setp   pid.y.Igain     [JOINT_1]I
setp   pid.y.Dgain     [JOINT_1]D
setp   pid.y.bias      [JOINT_1]BIAS
setp   pid.y.FF0       [JOINT_1]FF0
setp   pid.y.FF1       [JOINT_1]FF1
setp   pid.y.FF2       [JOINT_1]FF2
setp   pid.y.deadband  [JOINT_1]DEADBAND
setp   pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror 0.012700
net y-index-enable  <=> pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-pos-fb        =>  pid.y.feedback
net y-output        <=  pid.y.output
setp   hm2_7i96.0.stepgen.01.dirsetup        [JOINT_1]DIRSETUP
setp   hm2_7i96.0.stepgen.01.dirhold         [JOINT_1]DIRHOLD
setp   hm2_7i96.0.stepgen.01.steplen         [JOINT_1]STEPLEN
setp   hm2_7i96.0.stepgen.01.stepspace       [JOINT_1]STEPSPACE
setp   hm2_7i96.0.stepgen.01.position-scale  [JOINT_1]STEP_SCALE
setp   hm2_7i96.0.stepgen.01.step_type        0
setp   hm2_7i96.0.stepgen.01.control-type     1
setp   hm2_7i96.0.stepgen.01.maxaccel         [JOINT_1]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.01.maxvel           [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd    <= joint.1.motor-pos-cmd
net y-vel-cmd    <= joint.1.vel-cmd
net y-output     <= hm2_7i96.0.stepgen.01.velocity-cmd
net y-pos-fb     <= hm2_7i96.0.stepgen.01.position-fb
net y-pos-fb     => joint.1.motor-pos-fb
net y-enable     <= joint.1.amp-enable-out
net y-enable     => hm2_7i96.0.stepgen.01.enable
net home-y     =>  joint.1.home-sw-in
net y-neg-limit     =>  joint.1.neg-lim-sw-in
net y-pos-limit     =>  joint.1.pos-lim-sw-in
#  Tandem AXIS Y2 JOINT 2
setp   pid.y2.Pgain     [JOINT_2]P
setp   pid.y2.Igain     [JOINT_2]I
setp   pid.y2.Dgain     [JOINT_2]D
setp   pid.y2.bias      [JOINT_2]BIAS
setp   pid.y2.FF0       [JOINT_2]FF0
setp   pid.y2.FF1       [JOINT_2]FF1
setp   pid.y2.FF2       [JOINT_2]FF2
setp   pid.y2.deadband  [JOINT_2]DEADBAND
setp   pid.y2.maxoutput [JOINT_2]MAX_OUTPUT
setp   pid.y2.error-previous-target true
setp   pid.y2.maxerror 0.012700
net y2-index-enable  <=> pid.y2.index-enable
net y2-enable        =>  pid.y2.enable
net y2-pos-cmd       =>  pid.y2.command
net y2-pos-fb        =>  pid.y2.feedback
net y2-output        <=  pid.y2.output
# Step Gen signals/setup for tandem axis
setp   hm2_7i96.0.stepgen.02.dirsetup        [JOINT_2]DIRSETUP
setp   hm2_7i96.0.stepgen.02.dirhold         [JOINT_2]DIRHOLD
setp   hm2_7i96.0.stepgen.02.steplen         [JOINT_2]STEPLEN
setp   hm2_7i96.0.stepgen.02.stepspace       [JOINT_2]STEPSPACE
setp   hm2_7i96.0.stepgen.02.position-scale  [JOINT_2]STEP_SCALE
setp   hm2_7i96.0.stepgen.02.step_type        0
setp   hm2_7i96.0.stepgen.02.control-type     1
setp   hm2_7i96.0.stepgen.02.maxaccel         [JOINT_2]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.02.maxvel           [JOINT_2]STEPGEN_MAXVEL
net y2-pos-cmd    <= joint.2.motor-pos-cmd
net y2-vel-cmd    <= joint.2.vel-cmd
net y2-output     <= hm2_7i96.0.stepgen.02.velocity-cmd
net y2-pos-fb     <= hm2_7i96.0.stepgen.02.position-fb
net y2-pos-fb     => joint.2.motor-pos-fb
net y2-enable     <= joint.2.amp-enable-out
net y2-enable     => hm2_7i96.0.stepgen.02.enable
net home-y2     =>  joint.2.home-sw-in
net y2-neg-limit     =>  joint.2.neg-lim-sw-in
net y2-pos-limit     =>  joint.2.pos-lim-sw-in
#  AXIS Z JOINT 3
setp   pid.z.Pgain     [JOINT_3]P
setp   pid.z.Igain     [JOINT_3]I
setp   pid.z.Dgain     [JOINT_3]D
setp   pid.z.bias      [JOINT_3]BIAS
setp   pid.z.FF0       [JOINT_3]FF0
setp   pid.z.FF1       [JOINT_3]FF1
setp   pid.z.FF2       [JOINT_3]FF2
setp   pid.z.deadband  [JOINT_3]DEADBAND
setp   pid.z.maxoutput [JOINT_3]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror 0.012700
net z-index-enable  <=> pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-pos-fb        =>  pid.z.feedback
net z-output        <=  pid.z.output
setp   hm2_7i96.0.stepgen.03.dirsetup        [JOINT_3]DIRSETUP
setp   hm2_7i96.0.stepgen.03.dirhold         [JOINT_3]DIRHOLD
setp   hm2_7i96.0.stepgen.03.steplen         [JOINT_3]STEPLEN
setp   hm2_7i96.0.stepgen.03.stepspace       [JOINT_3]STEPSPACE
setp   hm2_7i96.0.stepgen.03.position-scale  [JOINT_3]STEP_SCALE
setp   hm2_7i96.0.stepgen.03.step_type        0
setp   hm2_7i96.0.stepgen.03.control-type     1
setp   hm2_7i96.0.stepgen.03.maxaccel         [JOINT_3]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.03.maxvel           [JOINT_3]STEPGEN_MAXVEL
net z-pos-cmd    <= joint.3.motor-pos-cmd
net z-vel-cmd    <= joint.3.vel-cmd
net z-output     <= hm2_7i96.0.stepgen.03.velocity-cmd
net z-pos-fb     <= hm2_7i96.0.stepgen.03.position-fb
net z-pos-fb     => joint.3.motor-pos-fb
net z-enable     <= joint.3.amp-enable-out
net z-enable     => hm2_7i96.0.stepgen.03.enable
net home-z     =>  joint.3.home-sw-in
net z-neg-limit     =>  joint.3.neg-lim-sw-in
net z-pos-limit     =>  joint.3.pos-lim-sw-in
# connect miscellaneous signals
#  ---HALUI signals---
net axis-select-x  halui.axis.x.select
net jog-x-pos      halui.axis.x.plus
net jog-x-neg      halui.axis.x.minus
net jog-x-analog   halui.axis.x.analog
net x-is-homed     halui.joint.0.is-homed
net axis-select-y  halui.axis.y.select
net jog-y-pos      halui.axis.y.plus
net jog-y-neg      halui.axis.y.minus
net jog-y-analog   halui.axis.y.analog
net y-is-homed     halui.joint.1.is-homed
net axis-select-z  halui.axis.z.select
net jog-z-pos      halui.axis.z.plus
net jog-z-neg      halui.axis.z.minus
net jog-z-analog   halui.axis.z.analog
net z-is-homed     halui.joint.2.is-homed
net jog-selected-pos      halui.axis.selected.plus
net jog-selected-neg      halui.axis.selected.minus
# net spindle-manual-cw     halui.spindle.0.forward
# net spindle-manual-ccw    halui.spindle.0.reverse
# net spindle-manual-stop   halui.spindle.0.stop
# net machine-is-on         halui.machine.is-on
net jog-speed             halui.axis.jog-speed
net MDI-mode              halui.mode.is-mdi
#  ---coolant signals---
net coolant-mist      <=  iocontrol.0.coolant-mist
net coolant-flood     <=  iocontrol.0.coolant-flood
#  ---probe signal---
net probe-in     =>  motion.probe-input
#  ---motion control signals---
net in-position               <=  motion.in-position
net machine-is-enabled        <=  motion.motion-enabled
#  ---digital in / out signals---
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-ext     =>  iocontrol.0.emc-enable-in
#  ---toolchange signals for custom tool changer---
# net tool-number             <=  iocontrol.0.tool-prep-number
# net tool-change-request     <=  iocontrol.0.tool-change
# net tool-change-confirmed   =>  iocontrol.0.tool-changed
# net tool-prepare-request    <=  iocontrol.0.tool-prepare
# net tool-prepare-confirmed  =>  iocontrol.0.tool-prepared
# toolchange passthrough
net tool:change iocontrol.0.tool-change  => iocontrol.0.tool-changed
net tool:prep   iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
Last edit: 09 Oct 2021 13:13 by Ekholm. Reason: pasted the ini file :)
09 Oct 2021 13:28 #222674 by snowgoer540
Replied by snowgoer540 on topic PlasmaC without THC?
there should be a _connections.Hal file. That’s where you’ll find the other stuffs (assuming you’re referring to arc ok and what not, I’m on mobile so I can’t see the attachments)
09 Oct 2021 15:58 #222687 by Ekholm
Thank you! Now I got it to work! Looking forward to test it tomorrow!
Time to create page: 0.095 seconds
