Exiting conversational
- phillc54
- Thank you received: 2100
20 Oct 2021 21:31 #223750
by phillc54
Replied by phillc54 on topic Exiting conversational
No, but there is work being done to sort out the differing python3 versions.
- Thank you received: 4155
20 Oct 2021 22:22 #223759
For the most part I was going to just run with the standard installation but now I want to see if I can come up with a rapid probing method.
Replied by rodw on topic Exiting conversational
Thanks. I think it was a misunderstanding on my part. I just assumed that a self compiled deb install and a RIP install could coexist.No, but there is work being done to sort out the differing python3 versions.
- phillc54
20 Oct 2021 22:25 #223761
by phillc54
I am sure I have just such a setup on one of my VM's.
Did you try removing the existing deb install with Synaptic before rebuilding.
- phillc54
20 Oct 2021 22:33 #223764
by phillc54
If it only QtPlasmaC that you are having path issues with then you can easily change the type in installation:
linuxcnc.org/docs/devel/html/plasma/qtpl...inuxcnc_installation
20 Oct 2021 22:43 #223769
Yeh I did that but the path remained pointing to the deb environment.
Perfect. I'll give it a try. There isn't much you have not thought of. I still gotta try framing.
So if I update the debs, do I uninstall them or do I just reinstall. I seem to remember there was a way that you could add files somehow that are included in the apt-get search path. Is it worth doing that?
- phillc54
20 Oct 2021 22:55 #223772
by phillc54
21 Oct 2021 19:40 #223860
Hmm git pulled the source and ran make right now, The build terminated with Missing Image docs/src/plasma/images/plasmac-conv-rotate.png.
This file does not exist in git hub
- phillc54
21 Oct 2021 22:41 #223873
by phillc54
Nor should it, it was removed a week or so ago.
You may need to make clean and/or run configure again.
21 Oct 2021 23:23 #223875
- snowgoer540
- Thank you received: 907
23 Oct 2021 06:57 #223982
by snowgoer540
Replied by snowgoer540 on topic Exiting conversational
The latest version of QtPlasmaC should fix the "RUN FROM LINE" issue. I say should because I couldn't get it to do it on my machine/VM, but instead of setting the text as part of an "else" statement, it now only sets the text when run from line is active.
Time to create page: 0.127 seconds
