Spotting Qtplasmac
  • paulsao
  • paulsao's Avatar Topic Author
  • Elite Member
  • Elite Member
20 Oct 2021 19:50 #223725 by paulsao
Spotting Qtplasmac was created by paulsao
Can someone help me with this, I made a gcode for spotting in Fusion 360 and activated the tool table for this, configure the treshold in 50v and the time in 200ms for 2mm stainless steel makes the first point and stops waiting for something and does not continue with the next point.
20 Oct 2021 20:13 #223730 by phillc54
Replied by phillc54 on topic Spotting Qtplasmac
Can you post the gcode file.
  • paulsao
  • Elite Member
  • Elite Member
20 Oct 2021 20:18 - 20 Oct 2021 20:19 #223731 by paulsao
Replied by paulsao on topic Spotting Qtplasmac
Thanks Phill this is my g code.
In F9999 remplace for cut Feed
Last edit: 20 Oct 2021 20:19 by paulsao.
20 Oct 2021 20:30 #223735 by rodw
Replied by rodw on topic Spotting Qtplasmac
Can you try increasing the spotting time? Some machines do not like short  spotting times we found when we came up with the idea. Mine needs at least 220 ms. Try 600 or more until you get it working.
The following user(s) said Thank You: paulsao
  • paulsao
  • Elite Member
  • Elite Member
20 Oct 2021 20:38 #223739 by paulsao
I tested it at 500ms but after that time the stainless steel plate is completely perforated because it is 2mm, I think I will try a 5mm stainless steel plate.
20 Oct 2021 20:50 #223742 by rodw
I think there is some latency from the internal torch relay etc that sets the minimum time that you can do. Before we did the timing thing I used to turn the torch off on receipt of an ArcOK which caused a much larger spot.
If you can do it at 500 ms, try going shorter until it stops working then go up a bit. Thats what I did.
20 Oct 2021 20:53 #223744 by phillc54
In your gcode you need to add $2 to the M5 lines in the spotting section.
They should read:
M5 $2
  • paulsao
  • Elite Member
  • Elite Member
20 Oct 2021 21:00 #223746 by paulsao
Thanks tomorrow I will test timed the latency of the plasma machine relay and I will manually add m5 $ 2 to turn off the torch, I will report the results.
  • paulsao
  • Elite Member
  • Elite Member
21 Oct 2021 10:48 #223825 by paulsao
Well I already work at the end adjust the time in 550ms and manually add $ 2 that was missing, I think I am wrong or the postprocessor has that problem.
21 Oct 2021 13:16 #223829 by MaikTheBike
Replied by MaikTheBike on topic Spotting Qtplasmac
I had the same problem and asked the same question:
forum.linuxcnc.org/plasmac/42673-postpro...smac?start=20#223698
Who wrote the PP for fusion ?
It shouldn't be too hard to add the " $2" to the Fusion 360 postprocessor ?
Time to create page: 0.133 seconds
