Powermax communications issue
- CFE
- Thank you received: 35
01 Nov 2021 23:41 #224938
by CFE
Replied by CFE on topic Powermax communications issue
Hi All,
Thanks for your replies and sanity checks
I got a RS485 to USB serial adapter, as per user guide. That worked right out of the box on the previous installation and with the same plasma unit, hence I am confused why it doesn't work now. I double checked the wiring, that all is good. I do not think it is something in QtPlasmaC, I assume it has something to do with python or the way usb devices are recognized by linux. I reinstalled python-serial. but to no avail. Not sure what to do. It's such a handy feature to have !
Cheers, Peter
Cheers, Peter
- phillc54
- Thank you received: 2100
01 Nov 2021 23:57 #224939
by phillc54
Replied by phillc54 on topic Powermax communications issue
Seeing as how it doesn't appear in the devices list then I don't think it is a python issue, more of an OS issue.
With the device unplugged enter lsusb then plug the device in and run lsusb again. The device should be listed.
- grijalvap
- Thank you received: 63
01 Nov 2021 23:58 #224940
by grijalvap
Replied by grijalvap on topic Powermax communications issue
Is your serial port listed?
you can check using ls /dev/ttyUSB*
then make sure the /dev/ttyUSBx devise is en the plasma c ini file
you can use putty or minicom to verify port is working, just need to make a loop from out to in the type in the putty or minicom if it is ok you should see what you are typing.
- CFE
07 Nov 2021 22:51 #225596
by CFE
Hi all,
I ran lsusb and the usb to serial adapter shows as :
Bus 002 Device 013: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
I have removed, purged and reinstalled python3-serial, but still no response if I run PMX485-test, except a message telling me to check the connections, which I have done. The device on on the Powermax communicator screen shows /dev/ttyS0. Starting to wonder if there is something going on in the plasma unit itself ? (Although we haven't touched it, and the plasma unit is only 2 months old.)
Cheers, Peter
Cheers, Peter
- phillc54
07 Nov 2021 23:26 #225598
by phillc54
I really don't know what is going on.
On my PC it always shows /dev/ttyS0 as a device whether I have my USB serial adapter plugged in or not.
When I plug in my USB serial adapter and click PORT SCAN then it adds /dev/ttyUSB0 as a valid device.
Your PC doesn't seem to be adding the USB adapter as a serial device.
- CFE
07 Nov 2021 23:43 #225600
by CFE
Hi Phil,
Before I upgraded to the 64-bit version our system did the same as what you describe, plug the USB adapter in, PORT SCAN, it added /dev/ttyUSB0 and we were away, no worries. Now I am on the 64-bit version and it stopped working. I had a look trough the BIOS and got everything USB related set at AUTO or ENABLED, so I like to think there is no issue there. It really is such a great feature if it works !
- phillc54
07 Nov 2021 23:51 #225602
by phillc54
What is the result of the last few lines if you unplug the adapter, plug it in again and enter dmesg in a terminal.
- Thank you received: 7456
08 Nov 2021 00:10 #225609
Replied by tommylight on topic Powermax communications issue
Also the port should be checked with
ls /dev/tty*
as USB devices have some naming issues, like ttyUSB or ttyACM or ..
ls /dev/tty*
- CFE
08 Nov 2021 00:22 #225611
by CFE
Hi all,
I ran dmesg and found the entries for the serial adapter near top end which show this :
4.833201] usbcore: registered new interface driver ftdi_sio
[ 4.834562] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 4.835080] ftdi_sio 2-6:1.0: FTDI USB Serial Device converter detected
I am reasonably sure that is the serial adapter, but then at the end of the dmesg output it shows this :
[ 6.696746] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 6.696769] ftdi_sio 2-6:1.0: device disconnected
I assume that has something to do with the issue, if the serial adapter disconnects from USB. But how to solve that ?
- phillc54
08 Nov 2021 00:45 #225613
by phillc54
This is what I see when I unplug my adapter:
This is what I see when I plug the adpater in again:So after plugging in the last line should be the attachment to ttyUSB0 or similar.
[ 1870.592430] usb 3-2: USB disconnect, device number 7
[ 1870.592563] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[ 1870.592572] ch341 3-2:1.0: device disconnectedThis is what I see when I plug the adpater in again:
[ 1878.330632] usb 3-2: new full-speed USB device number 8 using xhci_hcd
[ 1878.479817] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[ 1878.479819] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1878.479820] usb 3-2: Product: USB2.0-Serial
[ 1878.482001] ch341 3-2:1.0: ch341-uart converter detected
[ 1878.483414] usb 3-2: ch341-uart converter now attached to ttyUSB0Please Log in or Create an account to join the conversation.
