Powermax communications issue
09 Nov 2021 15:35 #225847 by grijalvap
Replied by grijalvap on topic Powermax communications issue
I see you already review the groups and rights, the last thing i can Think is the udev rules, you can google about the udev system this is haw Linux manage device events, however I really recommend you change the adapter for one with FTDI chip.
  • Moderator
  • Moderator
09 Nov 2021 15:52 #225848 by tommylight
Replied by tommylight on topic Powermax communications issue
He has the one with FTDI chip, those are used to program other stuff throught them.
Can you please boot the PC from USB with the older OS that worked before and check if it is still working there, takes about an hour of time in total and would confirm it is an OS or configuration issue, not a hardware one.
10 Nov 2021 01:08 #225901 by CFE
Replied by CFE on topic Powermax communications issue
That's a good idea, I will try that next week when I get back in the workshop. Thanks !
31 Dec 2021 00:59 #230375 by jtrantow
Replied by jtrantow on topic Powermax communications issue/brltty
I use a usb to serial adapter to talk to a GS2 VFD.
Today, I updated one of my machines with the 2.8.2 iso and I am having the same problem (dmseg shows ttyUSB0 goes away) because of brltty. I uninstalled brltty which fixed the ttyUSB0 issue but now I'm losing the network connections to the internet and the mesa 7i92.
Also mentioned in www.forum.linuxcnc.org/38-general-linuxc...ency-mesage?start=40
