cut recovery ext pin
- billykid
- Thank you received: 83
18 Jan 2022 09:39 #232246
by billykid
cut recovery ext pin was created by billykid
hi, i used eight external pins for power, start, stop etc buttons and they work great. I added four for cut recovery but it doesn't boot anymore and returns these errors
- Thank you received: 7485
18 Jan 2022 10:56 #232258
Replied by tommylight on topic cut recovery ext pin
Seems there is a refference to "oScale" somewhere but the pin does not exist.
- billykid
18 Jan 2022 11:59 #232274
by billykid
Replied by billykid on topic cut recovery ext pin
Yes Tom. look forward to Phill
I would not like it to be a locale problem this time too.
- snowgoer540
- Thank you received: 907
18 Jan 2022 19:04 #232315
by snowgoer540
Replied by snowgoer540 on topic cut recovery ext pin
I believe I see at least part of the problem.
But, can you post a backup of your config. Or at least the file where you connected these pins?
- billykid
18 Jan 2022 19:29 #232319
by billykid
here is the backup. the current custom_postgui file has 8 buttons and everything works, the "2custom_postgui.hal" file is the one with cutrec and does not go
- phillc54
- Thank you received: 2100
19 Jan 2022 00:55 #232372
by phillc54
Replied by phillc54 on topic cut recovery ext pin
Thanks for the report, a fix has been pushed.
The following user(s) said Thank You: billykid
- billykid
19 Jan 2022 08:29 #232412
by billykid
Well now it starts!
but for the manual x y movements before cutting they don't work?
I haven't tried yet because the pins on the 7i37 are almost finished
- phillc54
19 Jan 2022 08:36 #232414
by phillc54
It jogs fine here, from both the GUI buttons and the keyboard.
The fix for external cut recovery pins has no effect on jogging at all.
- billykid
19 Jan 2022 08:47 #232416
by billykid
it all works. i just wanted to say if there was a way to move x and y without keyboard and mouse.
however better as cutrecovery than normal jog
Thank you!
Thank you!
- phillc54
19 Jan 2022 08:56 #232417
by phillc54
If you want to jog X/Y without the GUI buttons or a keyboard then you need a pendant or similar connected to the appropriate halui jog pins.
linuxcnc.org/docs/devel/html/man/man1/halui.1.html
