cut recovery ext pin
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 Jan 2022 09:08 - 19 Jan 2022 09:09 #232419 by billykid
Replied by billykid on topic cut recovery ext pin
ok thank you Phill for the great job you are doing.
and to others who are collaborating with you.
Last edit: 19 Jan 2022 09:09 by billykid.
  • billykid
  • Platinum Member
  • Platinum Member
23 Jan 2022 11:09 #232869 by billykid
i used halui and now i can jog manually.
since I would like to make a single control panel with all the buttons, is there a way to switch them for jog and cut recovery or do I have to put them separate?
24 Jan 2022 01:26 #232916 by phillc54
Replied by phillc54 on topic cut recovery ext pin
If you are using the halui plus and minus pins for jogging then you could probably just parallel them with the external cut recovery pins similar to:
net  xPlusJog  your_right_button_pin  => halui.axis.x.plus  qtplasmac.ext_cutrec_e
net  xMinusJog  your_left_button_pin  => halui.axis.x.minus  qtplasmac.ext_cutrec_w
net  yPlusJog  your_up_button_pin  => halui.axis.y.plus  qtplasmac.ext_cutrec_n
net  yMinusJog  your_down_button_pin  => halui.axis.y.minus  qtplasmac.ext_cutrec_s
It would restrict your to only the n, s, e, & w cut recovery buttons but should work ok.
The following user(s) said Thank You: billykid
Time to create page: 0.178 seconds
