preview window
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Apr 2022 08:41 - 07 Apr 2022 08:53 #239541 by billykid
preview window was created by billykid
hi, I re-installed qtplasmac for the pci mesa, everything works but the workspace disappears as soon as I move the mouse. I can't explain myself well but the video helps.
Last edit: 07 Apr 2022 08:53 by billykid.
07 Apr 2022 08:44 #239543 by snowgoer540
Replied by snowgoer540 on topic preview window
Did you perhaps forget the video link? :)
  • billykid
  • Platinum Member
  • Platinum Member
07 Apr 2022 09:31 #239548 by billykid
Replied by billykid on topic preview window
I'm always wrong
07 Apr 2022 09:43 #239549 by snowgoer540
I'm always wrong
Nah, it happens to all of us from time to time :)
I am unsure on the bounding box, that looks like it might be a graphics/driver issue or something like that to me. I don't see that here.
But I do see an "issue" with your X and Y coordinate separating. From memory, to fix that, do the following:
In your INI file in the [KINS] section, remove the following from the KINEMATICS = entry:
kinstype=BOTH
You should be all patched up then.
  • billykid
  • Platinum Member
  • Platinum Member
07 Apr 2022 10:19 #239552 by billykid
unfortunately I don't have that line ...
07 Apr 2022 10:20 #239553 by snowgoer540
Can you post a backup of your config?  Made from the parameters (or settings) tab in QtPlasmac.
  • billykid
  • Platinum Member
  • Platinum Member
07 Apr 2022 10:29 #239554 by billykid
Here it was for the 7i80 now it is for the 5i23 pci, I only changed references to the card but also the computer.
12 Apr 2022 19:31 #240102 by snowgoer540
Sorry, this fell off my radar a bit.  I was able to simulate your config (thanks to help from Phill).  I don't see either the coordinate system issue, or any issues with things in the preview window disappearing here.
I think the graphical issues with things disappearing can be attributed to the new computer's hardware.  Perhaps it's driver related?  Sorry I cant be of more help at the moment.
The following user(s) said Thank You: billykid
  • billykid
  • Platinum Member
  • Platinum Member
13 Apr 2022 02:30 - 13 Apr 2022 02:59 #240115 by billykid
first of all thanks to you and Phill. now I have not tried anymore because I am running out of wiring. could it be a localization problem? I use Italian, once there was a problem.
even turning the z axis encoder after a few counts causes the problem.
Last edit: 13 Apr 2022 02:59 by billykid.
13 Apr 2022 05:11 #240125 by snowgoer540
You're welcome.
I am not sure on the localization, but if it worked on the other computer and your localization was Italian on that one, then I would suspect it's not the issue.
If it's not too difficult you could switch over to English and give it a try.
Time to create page: 0.294 seconds
