preview window
15 Apr 2022 07:34 #240313 by phillc54
Replied by phillc54 on topic preview window
Can you try toggling View Material in the Parameters Tab to see if that makes any difference.
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
15 Apr 2022 08:03 #240314 by billykid
Replied by billykid on topic preview window
Right Phill !! view material unchecked works
15 Apr 2022 22:29 #240369 by phillc54
This is going to be difficult to fix because I cannot see the issue on any of my machines, you may have to bear with us for a while.
Can you run the following command line commands:
linuxcnc_info
sudo lshw -C video > /tmp.video.txt
glxinfo > /tmp/glx.txt
Then post the following files:  /tmp/linuxcnc_info.txt   /tmp.video.txt  /tmp/glx.txt
  • billykid
  • Platinum Member
  • Platinum Member
16 Apr 2022 01:43 #240375 by billykid
it's the least I can do for you. the video card is integrated, but I tried to disable it and put a nvidia gt 520 without any difference here are the files
Time to create page: 0.082 seconds
