laser crosshair
  • aabtech
  • aabtech's Avatar Topic Author
  • Premium Member
  • Premium Member
12 Apr 2022 02:50 #240022 by aabtech
laser crosshair was created by aabtech
Hi, my question is how to setup a laser crosshair in QtPlasmaC.
  • aabtech
  • Premium Member
  • Premium Member
14 Apr 2022 13:56 #240251 by aabtech
Replied by aabtech on topic laser crosshair
What about the wiring of the laser crosshair? I have 5v laser cross model wiring it up is what I need.
14 Apr 2022 18:47 #240277 by phillc54
Replied by phillc54 on topic laser crosshair
I used a buck converter similar to below to convert from 24V:
core-electronics.com.au/dc-dc-adjustable...T3HavcIaAmiKEALw_wcB
14 Apr 2022 20:14 #240283 by rodw
Replied by rodw on topic laser crosshair
x 2 - got mine off ebay.
  • aabtech
  • Premium Member
  • Premium Member
14 Apr 2022 22:19 - 14 Apr 2022 22:21 #240286 by aabtech
  I already have a laser which is 5v what I need is setting up the hardware and software connection.
Last edit: 14 Apr 2022 22:21 by aabtech.
14 Apr 2022 22:57 - 14 Apr 2022 22:58 #240287 by robertspark
Replied by robertspark on topic laser crosshair
watch out with those little laser diodes l think the metal case is +5v, so if you put them in a metal holder which is at zero volts.... they are not long for this world being usable
put a bit of electrical tape around them before clamping them in a metal holder
Last edit: 14 Apr 2022 22:58 by robertspark.
  • aabtech
  • Premium Member
  • Premium Member
15 Apr 2022 05:35 #240307 by aabtech
How did you setup your laser crosshair show us step by step.
15 Apr 2022 17:02 #240350 by rodw
Install laser parallel to the torch so moving the torch up and down does not affect the laser position.
place some material under the torch
touchoff x0 y0
jog torch to near pierce height
Pulse the torch
jog machine x,y until the crosshair is exactly over the divot
Record the x,y DRO readings. These are your  laser offsets
Update them in your ini file
15 Apr 2022 18:12 #240353 by snowgoer540
Replied by snowgoer540 on topic laser crosshair
I mounted my laser to the non-moving portion of the Z axis. No need to fuss with any kind of perpendicularity to the table.
Follow these directions for setting the offset, no need to edit the .ini file manually:
linuxcnc.org/docs/devel/html/plasma/qtpl...l#peripheral-offsets
Time to create page: 0.576 seconds
