laser crosshair
- Thank you received: 4155
15 Apr 2022 19:15 #240359
Replied by rodw on topic laser crosshair
Well there is a need to be perpendicular because if you move from 1mm to 20 mm material, the results will be a different offset if not perpendicular
If I had a 3D printer I would make a clamp that sat high on the torch the laser pressed into but to machine something, I'm a bit lazy.
This would mean the laser was always in focus right at the torch tip..
- snowgoer540
- Thank you received: 907
15 Apr 2022 19:43 #240361
by snowgoer540
Replied by snowgoer540 on topic laser crosshair
In fairness, my laser does sit against machined surfaces (a corner) known to be perpendicular to the works. But I’d reckon you have to really try to make it cattywampus to a degree that would matter in a 19mm change of height… for a plasma starting offset.
- aabtech
- Thank you received: 16
17 Apr 2022 04:57 - 17 Apr 2022 04:59 #240451
by aabtech
Replied by aabtech on topic laser crosshair
How to setup laser crosshair in
HAL ?
HAL ?
Last edit: 17 Apr 2022 04:59 by aabtech.
- phillc54
- Thank you received: 2100
17 Apr 2022 05:06 - 17 Apr 2022 19:41 #240453
by phillc54
Replied by phillc54 on topic laser crosshair
I have this in custom_postgui.hal
# --- PLASMAC:LASER-ON ---
net plasmac:laser-on qtplasmac.laser_on => hm2_7i96.0.ssr.00.out-02
EDIT:
It would possibly be more correct to just add this line to your machine hal file (substituting the correct pin name):The config will then automatically complete the hal connection.
EDIT:
net plasmac:laser-on => hm2_7i96.0.ssr.00.out-02
Last edit: 17 Apr 2022 19:41 by phillc54.
Time to create page: 0.224 seconds
