Framing a metric GCode job on an imperial config
3 years 7 months ago #266455 by Doug @ Design8Studio.com
Maybe it is time for us to make Run From Line enabled as the default. It does seem to work well.
+1
As soon as I enabled it, it worked like a charm for me!
3 years 7 months ago #266457 by phillc54
I tried again with an imperial machine and the metric sample files and all worked correctly.
Do your gcode files have the G20  or the G21 codes?
The following user(s) said Thank You: Doug @ Design8Studio.com
3 years 7 months ago #266458 by snowgoer540
For your probe tests, if you change the number next to the probe-test code in the SETTINGS tab, that's the number of seconds it will pause for you to check with the gage block, so you don't have to move so fast.
For a bit of unsolicited feedback, your cut speed looks to be a bit too fast to me. For instance when it was cutting the globe perimeter, there was an excess of sparks spraying ahead of the torch, that's usually a sign that it's too fast for the amperage selected.
3 years 7 months ago #266464 by Doug @ Design8Studio.com
I am uploading two short videos... More on that below. But first...
I feel sheepish. I went to "repro" the framing issue, just to make sure before answering... and I could not reproduce the issue. I have no idea why framing was not working for me before. It happened on multiple files, and now it seems to be working fine, on both metric and imperial configs, with metric gcode files that have G21 code at the start. I should add that I rebooted the laptop just now. I feel like there were recent reboots with the issue I encountered before, but I cannot be positive.
However, I encountered another issue, but this time with "run from line" feature. When I first tried out the "run from line" feature for cut recovery, it worked great. At that time I was on a metric config with a metric file. I also have confirmed it working fine on an imperial config with an imperial file. But when I tried the "run from line" feature on an imperial config but with a metric file, I got an error about "cannot do G1 with zero" something or other. See video for specifics!
Video 1 of 2 (6 minutes):
Video 2 of 2 (2 minutes):
Note: as of when I am posting this, YouTube's "HD processing" is still ongoing on the first video. SD playback should be workable. It's saying another 25 minutes before HD viewing is ready.
3 years 7 months ago #266466 by Doug @ Design8Studio.com
Thanks for the awesome tips! I was just watching some plasma cutting video talking about air and amps, and was thinking I either need to lower my speed or up my cutting power!
3 years 7 months ago #266467 by phillc54
I cannot duplicate this issue on my imperial config with a metric gcode file. Is it possible to post the offending gcode file.
Time to create page: 0.134 seconds
