Framing a metric GCode job on an imperial config
3 years 7 months ago - 3 years 7 months ago #266449 by phillc54
You could have combined Run From Line with Cut Recovery to get to the previous shape a lot quicker.
linuxcnc.org/docs/devel/html/plasma/qtpl...plasma:run-from-line
OK, awesome, that took only about a minute point five to master, and it worked exactly like I had already tried / like I thought it should. My only question now is why on earth is that awesome feature "defaulted" to being not enabled?!?! :-)
That is probably a hang up from the "normal" LinuxCNC run from line that didn't take into account some settings and nor could you run from an arc. We did this so it runs through the gcode and sets everything (that we haven't forgotten) up correctly. You still cannot run from line within a subroutine but it "should" send an error message if this is attempted.
I just tried some framing with both an imperial sim and a metric sim using an imperial gcode and a metric gcode on each and it appears to work fine.
Can you post your gcode and let us know what units system the machine you tried it on was set to.
Last edit: 3 years 7 months ago by phillc54.
The following user(s) said Thank You: Doug @ Design8Studio.com
3 years 7 months ago #266450 by Doug @ Design8Studio.com
OK, I read that think I followed the better part of it. LOL
3 years 7 months ago #266451 by phillc54
Maybe it is time for us to make Run From Line enabled as the default. It does seem to work well.
3 years 7 months ago #266452 by snowgoer540
I just came here to say the same. I peeked at the code earlier today while we were enroute to our next destination, and there is a units correction which appears at least to be correct...
Like Phill said, your gcode may help.
3 years 7 months ago #266453 by Doug @ Design8Studio.com
The issue I had was when I opened an imperial config of QTPlasmaC, and then inside that, opened a GCode file that had millimeters set as the unit. The framing did not work right. This happened on multiple GCode files from multiple jobs, on the same imperial config. When I opened the same GCode file on a metric config, the framing was right. I will aim to try to post both my imperial setup / config info and one of the GCode files that had the issue. Thanks again!
3 years 7 months ago #266454 by snowgoer540
+1
Time to create page: 0.188 seconds
