- Thank you received: 46
Sure. Here's the metric GCode file that does "run from line" in a metric config, but errors out in an imperial config.I cannot duplicate this issue on my imperial config with a metric gcode file. Is it possible to post the offending gcode file.
Thank you! You all are awesome!
I understand about the framing thing. For whatever reason I cannot reproduce it either! If I ever encounter it again, I will do my best to document and investigate it!
