How to prevent the torch from moving up?
16 May 2023 21:13 #271470 by Bl484
Hi
I use QtplasmaC cutting configuration in Linuxcnc. How can I prevent the torch of the plasma machine from moving up, when I change material during the cutting process in Linuxcnc software?
When I use the following code which recommended by Linuxcnc, the torch goes up. but I don't want it.F#<_hal[plasmac.cut-feed-rate]>
M3 $0 S1
M5 $0
Could you please help me how to solve my problem?
  • Moderator
  • Moderator
16 May 2023 22:24 #271479 by tommylight
Replied by tommylight on topic How to prevent the torch from moving up?
Not sure what you want???
Moving torch up is basic plasma stuff, so i do not get it why would you want it down during changing material?
To break it easier? :)
16 May 2023 22:58 #271487 by Bl484
Replied by Bl484 on topic How to prevent the torch from moving up?
Thank you for your quick response.
You are right! When you use a plasma cutting machine, the torch should move up for every material change.
But, I want to use this configuration of Linuxcnc to run another machine which I designed for a special project.
All the features of the PlasmaC configuration are along with my purpose except moving up the torch!
17 May 2023 00:01 #271490 by phillc54
Replied by phillc54 on topic How to prevent the torch from moving up?
The torch height is controlled using external offsets:
linuxcnc.org/docs/devel/html/motion/external-offsets.html
It is not a material change that causes the torch to rise, it is part of a sequence of events stated by a spindle stop (M5 $0) or an error/abort during a cut.
You could possibly prevent it with a bit of hal work on the axis.z.eoffset-enable pin. You would need to be very careful is this would cause repercussions later if the Z axis is not where it is expected to be.
The following user(s) said Thank You: Bl484
17 May 2023 22:52 #271573 by Bl484
Thanks,
You got my point.
So, is it possible to remap the M05 to prevent rising the torch?
17 May 2023 23:35 #271581 by Bl484
Another question:
The safety height parameter controls the amount of rising of the torch.
But I cannot set this parameter to zero!
If I could have set it to zero, my problem would have been solved.
Do you have any suggestions?
18 May 2023 08:13 #271596 by phillc54
Another question:
It that will work for you then I will have a look tomorrow.
19 May 2023 06:05 - 19 May 2023 06:12 #271651 by phillc54
A quick an dirty method to test whether this may work for you is to change the value via HAL while QtPlasmaC is loaded.
unlinkp plasmac.safe-height
setp plasmac.safe-height 0.000001
You cannot use zero as there is an inbuilt fallback which sets it to maximum Z height if zero is detected.
I am assuming a very low value will be good enough to test with.
Last edit: 19 May 2023 06:12 by phillc54. Reason: setp, not set
22 May 2023 23:43 #271981 by Bl484
Thanks a lot. It works.
 When I used your recommended HAL command, It worked. But I cannot use them in HAL files (and *.pref file)!
When I set the safe height parameter to a non-integer number, the software does not accept it, and this parameter will change to 100!
It means I should adjust it every time in the setting panel and use the HAL command.
23 May 2023 00:15 #271985 by phillc54
Can you try the commands in a postgui Hal file.
If it is worthwhile I could change the code so that you could set it to zero from the parameters.
Time to create page: 0.223 seconds
