How to prevent the torch from moving up?
- Bl484
23 May 2023 07:55 #272005
by Bl484
Replied by Bl484 on topic How to prevent the torch from moving up?
Thanks, I substituted those commands in the Postgui HAL file. Problem solved.
I think it is worth changing the main code. The program will become more general.
Cheers!
Cheers!
- phillc54
- Thank you received: 2100
23 May 2023 11:19 #272014
by phillc54
Replied by phillc54 on topic How to prevent the torch from moving up?
I will have a look over the next day or so.
What is the reason for doing this?
- Bl484
24 May 2023 00:34 #272063
by Bl484
While I can not give technical details due to the confidentiality, it is to mimic QtplasmaC's THC feature to precisely manage vertical distance.
- Bl484
25 May 2023 01:07 #272126
by Bl484
Dear Phillip,
I wanted to ask you if there is any way to disable the probing routine, but I found your following answer to a similar question:
"Probing in QtPlasmaC is controlled by the plasmac component and it is not able to be bypassed"
But, I need to use QtplasmaC/Plasmac configuration for my project Because I need to use the THC feature. I tried to activate THC by using M65, but it didn't work. As I understood, using M3 is the only way to activate THC.
Is there any way to activate THC without using M3?
Regards
Regards
- phillc54
25 May 2023 03:18 #272131
by phillc54
No, it requires the M3 to begin the sequence.
There is a standalone THC component.
linuxcnc.org/docs/devel/html/man/man9/thc.9.html
- grijalvap
- Thank you received: 63
25 May 2023 23:05 #272176
by grijalvap
Replied by grijalvap on topic How to prevent the torch from moving up?
Is hard to help when the things are explained and the correct questions are made, but is almost imposible if you can't provide details.
- Thank you received: 7463
25 May 2023 23:34 #272178
Replied by tommylight on topic How to prevent the torch from moving up?
Another "inventor" ?
Time to create page: 0.109 seconds
