QTPlasmaC with fourth axis - rotary
3 years 4 months ago #273182
Replied by tommylight on topic QTPlasmaC with fourth axis - rotary
Round tube = no THC and no 4th axis, must have float switch or ohmic, makes work much smoother.
Square tube = some types/sizes would be just fine wrapping the total of all lengths (yes lengths
), without radius's, but most will not be comfortable work doe to extinguished arcs and/or torch hitting material.
3 years 4 months ago #273187
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic QTPlasmaC with fourth axis - rotary
The torch will not hit if the Z axis is driven by Gcode like the Sheetcam plugin does.
Regards
Marius
www.bluearccnc.com
3 years 4 months ago #273190
Of course, i was talking about the general use case that some types/sizes can work with no complicated/SheetCAM math. Just plain gcode wrapping.The torch will not hit if the Z axis is driven by Gcode like the Sheetcam plugin does.
- snowgoer540
- Thank you received: 907
3 years 4 months ago #273222
by snowgoer540
This feature is something I asked Phill for way back when. I use it for my spring loaded marker holder I 3D printed with a marker to make templates, mark wood, etc. I also have a spring loaded diamond drag engraving tool that I use as well from time to time.
Currently QtPlasmaC handles nothing with "probing" in this mode. Z is set similar to how you would on a milling machine. I literally jog Z down to a point that the marker/scribe is touching the material, and then zero the Z DRO. Works well since all of the Z heights are controlled in the GCode, and any irregularities in the material is absorbed by the spring(s). None of the code I run requires an M3 though.
I imagine the component would have to be modified to probe to find Z0 and then allow the G-Code to drive the Z movements. I'm sure it's not impossible though, I can confer with Phill and see if I/we could possibly add something.
Replied by snowgoer540 on topic QTPlasmaC with fourth axis - rotary
Does anyone know how QTPlasmaC handles referencing when keep-z-motion = 1?
3 years 4 months ago #273228
by mariusl
Regards
Marius
www.bluearccnc.com
Then it could be possible to probe using Gcode like G28 or G32. The old fashioned way for plasma to probe material height.
Regards
Marius
www.bluearccnc.com
3 years 4 months ago #273229
by mariusl
Regards
Marius
www.bluearccnc.com
Yes agreed. Hence my hunt for a decent solution. It is beginning to look like we can find a solution by using Z movements and the Sheetcam plugin combined.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.072 seconds
