Possible to manually use laser on a dry run ?
- snowgoer540
- Thank you received: 907
You may call me GregUPDATE:
Working good now Snowgoer.
Thanks again.
Can now turn the laser on/off from my pendant, woohoo
Glad to hear it; good work!
- beefy
- Thank you received: 58
just a little update seeing as you asked about my subroutine before.
I figured out how to do it (I hope), and this is the new code:
o<torch-to-crosshair> sub
G91 (Change to incremental mode)
G0 X60 Y40 (Move torch by laser offset amounts)
G90 (Change back to absolute mode)
G10 L20 P0 X[#5420-60] Y[#5421-40] (now set the DROs back to what they were before the move)
o<torch-to-crosshair> endsub
So I turn on the laser, and simply treat it as though it was the torch.
I do the dry run to check the torch (crosshairs now) won't go anywhere I don't want.
Once OK press the button to run the sub, the torch moves to where the laser was, and then the XY DROs are set back to the position before the move.
Works great.
Thanks again for all your help.
- snowgoer540
Clever; that seems like a good approach! Thanks for sharing.
I think my only comment would be that it prevents using the laser button to align to a crooked sheet. For my work flow, I generally make the sheet square to the table (which is square to the gantry), because I rarely cut anything that's heavy, and my table isn't big enough for full sheets. So for me it's rare that I use the edge alignment feature of the laser button, and the subroutine would work nicely.
I may take a look at doing a dry run with laser offset applied in the future, especially because I would like to better understand the plasmac component, but for now this seems to be a nice workflow.
- beefy
I'm also a bit lost of the "edge alignment feature of the laser button", must be something I've missed in the manual.
The subroutine doesn't necessarily zero the XY co-ords after the the peripheral offset correct move, it just puts them back to whatever they were before the move, so the torch ends up where the laser was but with the same co-ords.
So at the end of the dry run move the XY position could be anywhere for instance, and I could run the sub then.
Could be useful if I have a situation where I know a location on a partially cut sheet is X489.3 Y278.6 (a pierce point for example). So I jog the crosshairs to that location, set the work co-ords to those values, and do the dry run, then run the sub after.
Hope that made sense.
- snowgoer540
I wouldn't say I don't use the laser touch off routine at all, I just haven't played with that yet.
Take a peek at "To set the origin with rotation" in this section: linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#plasma:laser
I think so, I will try to find time to play with this at the machine in the next few days.
- beefy
Greg,
I'm actually really happy you mentioned that one. I've seen that one in the manual but was left thinking what does it mean with rotation.
So if I've got this right it seems very similar to Sheetcam's "align" feature, which is used if the sheet is laid diagonally on the table.
However, with Sheetcam you have to check 2 points on the sheet on the table then go back to Sheetcam to enter those points so it can rotate the drawing.
Looks like Qtplasmac can do the same thing right at the table. I just keep getting Xmas presents, so a big thanks for bringing that to my attention.
Once I physically install my lasers that is the next thing I'll try out.
Keith
- snowgoer540
Greg,
Thanks for this feedback, I added a line in the docs to clear this up. Sometimes it's hard to write docs assuming someone knows nothing about the features when you're already familiar with them... You are right; it was ambiguous.
I didnt know sheetcam could do this, but it does sound like a bit of a PITA. Good to know anyways.
Keith
Enjoy! I didnt get to the table tonight to play with your subroutine. Maybe tomorrow...[/quote]
