Arc Ok Problem
24 Feb 2024 23:50 #294287 by phillc54
Replied by phillc54 on topic Arc Ok Problem
Thanks I just found that myself, hope that gets me going to cut the parts then I can dig into why QTPlasmaC is failing. I did use it some time back so was surprised when I gave me a problem
Have fun
Tom
Plasmac2 shares quite a few libraries with QtPlasmaC so I imagine that you will have similar issues.
Did you check these hal pins with Halshow?
forum.linuxcnc.org/plasmac/51809-arc-ok-problem#294139
25 Feb 2024 01:08 #294306 by kn612
Replied by kn612 on topic Arc Ok Problem
Could your joint 2 on limit switch error be the main issue? When the arc starts would it cause noise through to your joint 2 limit input causing it to stop cutting?
25 Feb 2024 01:12 #294308 by acourtjester
Replied by acourtjester on topic Arc Ok Problem
Thanks Phill
I will look into those things
This may interest you here is a video from today doing what I call center punching routine. I use this to position hole that I will drill after the part is cut. this worked as I wanted the only different is the tool selection in SheetCam??
when I switch to the part cutting routine with a different tool in SheetCam that is the G-code that I have a problem with getting the error I posted
drive.google.com/file/d/1NmO-lchR3Nk8uSa.../view?usp=drive_link
I did have the material list that can be accessed in QTPlasma from it's conversion form the SheetCam tool list
25 Feb 2024 01:22 #294310 by phillc54
The spotting looked good. You probably won't get the arc-ok LED's on the GUI to light when doing that because of the delay.
Materials 1000000 and over are not in QtPlasmaC unless the current gcode file sets them up, they are only temporary for that particular job.
25 Feb 2024 01:31 #294311 by acourtjester
 here are the 2 G-codes and it seem the starts are the same changes on line 23
File Name: newparts.zip
File Size:6 KB
25 Feb 2024 01:41 #294314 by phillc54
They both look fine, the temporary materials are setup correctly and they both run fine here on a sim config.
For your centre punching  you should look at this and then you can set up the spotting parameters on the PARAMETERS tab:
linuxcnc.org/docs/2.9/html/plasma/qtplas...html#plasma:spotting
25 Feb 2024 01:46 #294316 by acourtjester
thanks Phill
my routine work fine, I am a real beginner and do not want to introduce new things right now. It seem maybe I should change the mode from 1 to 0
25 Feb 2024 03:37 #294325 by phillc54
You shouldn't need to change to Mode0 unless your plasma power supply is faulty and not emitting an arc-ok signal.
25 Feb 2024 04:03 #294331 by acourtjester
OK just guessing
25 Feb 2024 05:31 #294335 by acourtjester
OK Phill
different question, When using other controllers and other software I could turn off the THC and cut with just the G-code instructions and cut parts.
It seems to me the reason for the material list is for getting the THC perimeters.
As it sits now I can run the G-code without plasma on and it will run the complete G-code with out cutting no problem. Turn on the plasma and it stops at the first cut operation, with an error.
Time to create page: 0.261 seconds
